Emphasis on Home insulation - perhaps too high.
@kev-m, that’s a useful explanation, which makes sense.
@derek-m your system and the way you’ve implemented sounds super interesting. Should make for an interesting and helpful review.
I'm curious what the practical difference is between an A2A air con unit and an A2W ASHP using a fan coil? Most heating-based ASHP systems are using radiators or UFH and so you're limited by the passive airflow. A2A units use a fan to blow air over the evaporator (in cooling mode), while A2W fan coils blow air over the water pipe fed from the internal side of the ASHP. In A2A there's a phase-change going on, while in A2W it's just regular deltaT (cold water in, warm water out).
So I'm wondering how much of the heat transfer is due to the phase change, and how much is just the fan pushing more air through than you'd get from a passive system?
Hi Prunus,
Let me see if I can explain the main differences as far as I understand them.
In the A2A ASHP, the compressor which is located in the outdoor unit, compresses and heats the refrigerant gas. This gas then flows through the high pressure pipe to a heat exchanger (Condenser) located within the indoor unit. This heat exchanger is basically a finned coil over which a fan blows air and thereby extracts heat energy from the refrigerant gas. As the gas cools, it starts to condense, and flow back to the outdoor unit via the low pressure pipe. In the outdoor unit the refrigerant, in liquid form, flows through a further finned coil heat exchanger (Evaporator), where it absorbs heat energy from the outside air and evaporates back into gas form. The refrigerant gas then flows back to the compressor where the cycle starts once again.
In the A2W ASHP, the compressed and heated refrigerant gas flows to a different type of heat exchanger (probably a plate type), in which the refrigerant gas and the central heating water are in good thermal contact with each other. The hot gas therefore heats the water, which in turn carries this heat energy into and around the building.
Similar to the A2A system the condensing gas then flows back to the evaporator where it is evaporated using heat from the outside air and the cycle starts again.
The main difference between the two systems is therefore the type of heat exchanger used as the Condenser.
The other difference is that the A2A can be safely used for cooling as well as heating, which is not the case with the A2W.
Regards,
Derek.
@derek-m A2W can be used for cooling. Many are reversible so you can switch the outdoor unit to making cold water instead of making hot water. The problem is that most people then plumb it into radiators or UFH. If it's cooling below the dew-point, you get condensation. People don't like sweating radiators or puddles of condensation on the floor, and they don't like the cold feet effect from standing on a cooled floor when the air is still hot.
A fan coil is just like a car radiator in reverse - cold water goes in, fan blows room air over radiator, air cools, water heats up, warm water comes out. Humidity that comes out of the cooler air is collected and piped to drain away. Having a fan means the air is mixed so you aren't relying on passive convection. It's like a fan oven has much better temperature uniformity than a convection oven. You can also use a fan coil in heating mode, and for the same heat output you need a smaller size than a passive radiator.
So my question is getting at: what is the difference in efficiency (quantity of heat transferred) between a fan coil driven by an ASHP in cooling mode and a A2A unit which inside the box is doing a phase change of refrigerant from liquid to gas? Phase changes absorb more energy, but I don't have an idea what kind of scale how much more in this situation.
Hi Prunus,
You are perfectly correct about the phase change from gas to liquid and liquid to gas as being the points where maximum energy transfer occurs.
I think we need to clarity terminology, since there seems to be a little confusion.
Certainly as far as qualification for RHI payments are concerned, what you describe as a 'fan coil' would be termed the indoor unit of an A2A ASHP or more commonly called an Air Conditioning Unit and would not qualify for RHI. Whilst it is feasible to use water as the cooling medium in the 'fan coil', it would not be as efficient as using refrigerant gas, since there would be no phase change occurring in the indoor 'fan coil' unit. Also without adequate protective devices it may be possible to freeze the water in the Evaporator, which would not be desirable.
For these reasons what is described as A2A ASHP only use refrigerant gas as the transfer medium.
The A2W ASHP as defined for RHI qualification uses the refrigerant gas to heat water, which is then used to transport the heat energy to the points of use.
As you have stated you could quite easily have the problem of puddles of water around your radiators or UFH if an A2W system was used for cooling.
To try to answer your question about the difference in efficiency between heating and cooling of an A2A ASHP.
I recently installed a A2A system, primarily for heating but also for cooling when required.
To quote the manufacturers specification:-
Cooling Capacity is 2.6kW with a Seasonal Energy Efficiency Ratio (SEER) of 6.2
Heating Capacity is 2.62kW with a Seasonal Coefficient of Performance (SCOP) of 4.2
Whilst the actual heating and cooling capacity is approximately the same, in heating mode it is expected to be less efficient overall compared to cooling mode. This is due to the fact that when the ambient air temperature falls below 5C, the efficiency of the ASHP starts to reduce, and can fall by as much as 50% under sub zero temperatures.
I hope that this answers your questions.
Regards,
Derek.
On the subject on cavity insulation, just came across these guys: https://www.evobead.co.uk
- 2,541 Topics
- 59.2 K Posts
- 487 Online
- 6,822 Members
@toodles If I ever catch myself feeling hubristic I ...
By Papahuhu , 2 hours ago
Why? Factor in 85% efficiency for that oil boiler and...
By Old_Scientist , 2 hours ago
I've been watching this with interest as I would like s...
By JohnnyB , 3 hours ago
RE: Aerotherm 12+12kw cascade huge power utilisation
What the hell. There is exactly one reason to use a h...
By bobflux , 3 hours ago
Thanks for such a comprehensive response!!! ...
By errmm , 4 hours ago
By Eliuccio , 8 hours ago
By gajolos , 14 hours ago
By RobS , 15 hours ago
By Toodles , 1 day ago
By ChandyKris , 1 day ago
By Jonatan , 2 days ago
By Gruff2001 , 2 days ago
By antonical , 3 days ago
