Does your heat pump...
Does your heat pump calculate and provide you with a COP figure or do you need additional metering equipment to work out your COP? Poll is created on Nov 27, 2022
Does your heat pump calculate and provide you with a COP figure?
16 Users
10 Reactions
12.2 K Views
How easy is it for you to work out your COP? Does your heat pump offer that information up easily or do you need to jump through hoops?
Topic Tags
Mitsubishi Ecodan/FTC6
No COP on controller but does give some limited info on energy consumed and delivered so you can calculate it.
The Melcloud app does give COP but you need the Mitsubishi wireless module.
Midea 14kW with Midea Controller - short answer is no.
If I add the Midea app, I get daily kWh in and kWh out, meaning I can manually (and tediously, the numbers need to be copied manually) calculate daily COPs. The hourly consumption figures are a little suspect, always an integer, and is the daily figures are sums of the hourly figures, errors could accumulate.
More generally, I think it is worth remembering that manufacturers providing COPs, directly or indirectly, are in effect manufacturers marking their own homework.
Morgan
(@morgan)
@Kev M
Can you explain how to access that please.  I have Melcloud app and the Mitsubishi wireless 'stat'.
Hi @Morgan
The wireless module I mean is the little box that connects to the FTC, not the wireless controller.  I got this when I had MMSP installed (I could have had it with the original install but I declined). In Melcloud I get this:
Screenshot 2022 11 27 13.08.30
On the wired in controller (not the remote wireless one) the button on the right of the row of 4 gets you access to the energy consumed and delivered menus.
Morgan
(@morgan)
@kev-m
I have the little wifi box wired into the FTC that you speak of but I only get this.
Screenshot (13)
(@hydros)
We have a Daikin Altherma. It’s doesn’t tell you a COP value. The info it can display is heat energy generated for hot water and heating. It also rather handily displays run time and starts for the compressor. This is only available via the controller, there is no app for this generation of Daikin heat pump. I believe the later gen, Altherma 3 comes with remote access but still displays limited info. Over all not very impressed with the system, still tweaking it after 18 months.
I do have external monitoring to enable me to calculate COP (part of a trial with OVO), whilst I don’t have access to the real-time data I do record the values on the meters and calculate COP myself. The energy generated value on the Daikin is usually very close to that measured by the external monitoring.
(@mike-patrick)
I think this is a widespread omission for heat pumps in the residential market. Mine's a 6 year old Grant Aerona and there is no way to find this information (other than hooking up additional separate equipment) from the control panel.
The end consumer is generally discouraged from delving into the control panel, although I have done so in order to adjust the weather compensation settings.
I understand that you don't want consumers going into all the settings but they should be able to easily see the performance (COP) on a display and be able to make adjustments to settings such as weather compensation. The ideal values for this can only be determined after running a heat pump over a period of time and seeing what works best for the particular installation. End users shouldn't have to call in a heating engineer every time they need to fine tune these. Many heat pumps show their origins in the industrial/commercial market and have yet to develop into consumer friendly appliances. This hinders their widespread acceptance.
I get quite frustrated when I read posts on this forum saying, "I'm achieving a COP of X....", and I wonder how the user is able to do this when I have no means of determing the figure for my pump. It should be like fuel economy on a car. A figure you can read instantly off a display. Any change in the figure can be an early indicator of a potential problem.
Mike
 robl
(@robl)
Totally agree, COP should be the headline information when looking at how the heatpump is performing.  It is hard to measure accurately though - for hard, read a little bit expensive.  Perhaps the manufacturers skimp on sensors, and don't want to display prominently information that is suspect?  For my own diy heatpump, I spent £40 on sensors to allow COP to be calculated using +/-0.1C temperature sensors that have to be carefully positioned - that and the flow rate limit the accuracy of the heat measured.  Electricity is easy in comparison - we have an off the shelf 1% accurate meter, which outputs pulses.  Rolling the errors together, a reported cop of 4.0 could be 3.8 or 4.2.  It is brilliant as a "everything is alright" indicator that I look at every now and then.
(@batalto)
I use my COP figures as a broad brush and they do show what would be expected - lower flow temps and warmer days are more efficient. I am not sure what people want from a COP daily though. Its fine, but what are you going to do? The only way to be more efficient is to run at lower flow temps - that's it. So lower your flow temps until the house is just right and there really isn't anything else you can do. Or am I missing something?
262m2 house in Hampshire
Posted by: @morgan
@kev-m
Screenshot (13)
I think you need MMSP or similar to get the COP.  Does it show you energy delivered or just consumed?
Posted by: @batalto
There are people who record every gallon of petrol they use and mpg for each tankful, with tables and graphs going back years.  These folks will want to know daily COP, nothing less will do.
It's useful to know as an indication of anything going wrong I suppose?
This post was modified 3 years ago by Kev M
Page 1 / 4
