Choice of heat pump...
Choice of heat pump - Help needed - Vaillant Arotherm versus Samsung versus Logic Air versus Grant Aerona
11 Users
9 Reactions
(@majordennisbloodnok)
Noble Member Moderator
@toodles
Not going to suggest I find it desirable, btw.
This post was modified 10 months ago by Majordennisbloodnok
@majordennisbloodnok 🤯
Graham Hendra
(@grahamh)
tbh there isnt a lot of difference between the heat pumps listed, they are all good, all small, all quiet etc.
But the service levels are dramatically different. The best heat pump service for after care is Ideal, simply awesome, i cant rave about it enough. The rest ok at best .
I'm literally Mr Samsung, ive sold them for 15 years, ive had every model on test at home over the years. all really good, but I have an Ideal at home now and Ideal couldn't be more helpful they are setting the standard for after care and everyone else needs to catch up.
Vaillant never tried them, likewise grant. I've never had need to look into them, they are similar to Samsung etc so why change brands?
but whatever you put in good luck and welcome to heat pumps. GH
Heat pump builder
Posted by: @grahamh
But the service levels are dramatically different. The best heat pump service for after care is Ideal, simply awesome, i cant rave about it enough. The rest ok at best.
Posted by: @grahamh
Silly question, perhaps, but if you haven't tried Vaillant or Grant on what criteria are you judging that their customer service is "OK at best"?
Graham Hendra
(@grahamh)
fair points ive not tried them on aftercare but tbh i haven't tried very hard with either of them, never had the need, they are just average heat pumps in a sea of average heat pumps. never needed to change brands so far.
Heat pump builder
Posted by: @grahamh
In fairness, then, nor can you say they are average. All you can justifiably say is that you know Samsung and Ideal well and have insufficient experience with the others to comment.
Having stated you have a commercial interest in Samsung and Ideal, I’m afraid I’m not comfortable with you making negative comments about other brands without backing them up with evidence.
(@judith)
Vaillant service for the application installation was great, one engineer visit and 4 extensive replies from the help desk. BUT tbh it should have been better coded so that the customer didn’t need to reinstall an app 3 times to get it right!
@judith If it is any consolation @judith, the Daikin app is no better; that took many attempts to install and every few months, it loses all identity and has to be re-installed. Every time I open the app, it informs me it has found a new unit on my set-up and wants to install it…. as many times as I tell it to go ahead, it just sits there informing me it is installing…….. installing…. installing. And I only ever use the app for a glance at consumption patterns! Regards, Toodles.
 NJT
(@njt)
@toodles
We've only just had our heat pump installed last week, and it's lost all info on the app 4 times already 😐
(@broadsman)
@grahamh.
I have recently had a Samsung 12.5Kwh, Gen 7 fitted. Wish Samsung had written the User Manual for homeowners without a degree in space technology and had used a vocabulary in general UK use. As a sales rep Graham, do you have such a document? Thanks.
(@elton)
I still struggle to understand this re: Samsungs: https://renewableheatinghub.co.uk/forums/postid/32750
bontwoody
(@bontwoody)
@elton
Which bit are you having problems with?
I have a Samsung which performs well so might be able to help.
Page 2 / 2
