@toodles I thought all this nonsense stopped when they became regulated. And particularly so if samsung accredited.
thats the lads just left having filled the cavities properly this time.
Posted by: @toodles@derek-m Ah! Now that is another matter of course!
On standard radiators it would appear that the flow is on the left.
Posted by: @derek-mWhat documents should the customer receive?
Part-L Section-9 provides a list of what to expect
Only the installer could generate this main instruction manual.
Note 9.2b where the instructions need to cross-reference to the manufacturer's manuals for each device installed on-site.
Personally, for 9.2a(iii) I think the installer would find it quicker to take a photo which shows the position of each adjustable device/valve, and label it.
That's easier for everyone, instead of trying to follow a text-based description.
@transparent the insulation guys for the cavity were out Friday removing my insulation and they stick want things in to agitate the insulation combined with compressed. Today we were looking at our power usage and surprised it was 2 quid. Then it dawned on us there is no heating. Checked all the fuses etc, pressure ok but short of opening the heat pump cover and testing I have no idea if power has been cut.
does the controller give any data as to when it stopped producing heat. No water either so stuck it on standard and I suspect it uses the immersion.
@derek-m nothing shut off, checked master switch and 240 in and out to pump, so not a damaged cable.
is it possible it’s ingested some of the dust from them drilling and core cutting. It was covered in dust and if running at the time sucked crap in those vents.
@derek-m found the fault, during Saturday the power went off twice and seems to have defaulted to a zone mode. I went through the field settings and corrected it. As a point of interest, can you fault find these with a meter or is it a laptop job. And would samsung give me an installation manual do you think.
booked samsung to come out in a weeks time to look at this install, the bloke is on holiday and returns in a week.
I'm pleased to hear that you have discovered the problem, my next suggestion would have been to check the controller settings.
You should be able to download an installation manual. Google the model number and follow the various links.
@david999 is it Kevin?
It's most likely Kelvin.
He's got more degrees.
- 2,131 Topics
- 21 Online
- 5,656 Members
By Old_Scientist , 10 minutes ago
By Transparent , 4 hours ago
By PatrickVito , 1 day ago
By Tim441 , 2 days ago
By Tim441 , 4 days ago
By Toodles , 4 days ago
By Abernyte , 4 days ago
By Eliuccio , 6 days ago
By Scalextrix , 6 days ago
By Mars , 6 days ago
By Mars , 7 days ago
By Scalextrix , 1 week ago
