ASHP retrofit to 19...
ASHP retrofit to 1970s semi
3 Users
4 Reactions
 Kuba
(@kubak)
Hi, thanks for your great YouTube channel and setting up the renewable heating hub. I've learned a lot already!
We're in a 1970s semi in small town in the Lothians. We're planning an extension next year, and it looks like we'll have to upgrade our boiler. As such, I've started looking into air source heat pumps as an alternative. Leaving the "should or shouldn't I?" question for later, I'm trying to get a better idea of the scope of work. Our current footprint is 80sqm, extending to 110sqm, which would add a shower room, bedroom/office, and living area. I have a few questions regarding installing an ASHP:
  • All of our radiator piping is 8mm microbore. Would this cause issues for an ASHP? I'd rather avoid that work, but I suppose during building would be the best time to do it. I might also consider just doing underfloor heating throughout the downstairs, if the cost is similar to replacing the 8mm piping. In that case, would keeping microbore upstairs be okay? The radiators are usually turned down pretty low upstairs anyway.
  • We weren't planning to start the build until spring 2022, but that's after RHI ends. This will be replaced by the Clean Home Grant, but it seems to me that this won't provide as much support as RHI - is that correct? Are there any other schemes that I should be aware of?
  • We'll need to add cavity wall insulation, increase loft insulation, and re-render the house. To claim RHI, could we do this and the heat pump installation at the same time, or do we need to have all the insulation and an EPC done before we commission the ASHP? Does the Clean Home Grant work similarly in terms of EPC?
  • Any recommendations for local installers in the Lothians or wider area in Scotland but willing to travel?
  • I'm really excited about the technology, and I'd love to make this work, but in the end it'll boil down to budget. If it's not meant to be, are there things we should consider during the extension that would make installing an ASHP easier in the future?
I'm sure I'll have more questions later, but I'll leave it at that for now.
Thanks!
Kuba
Topic Tags
@kubak
  • I assume you're getting planning permission for your extension?  If so and you want an ASHP you might want to include it.  Otherwise check out the permitted development requirements for ASHPs for Scotland; there are some restrictions
  • @Julianc has installed an ASHP with microbore, maybe he can advise?  I would have thought ufh would be a lot more expensive than replacing the microbore pipes (if you need to). Even if you don't have ufh you might have to have bigger radiators.
  • I don't know about Clean Homes Grant but I think Scotland may have its own schemes not available to England?
  • There is nothing to stop you doing the work to improve insulation during or even after the ASHP installation and commissioning but you'll need it done before you apply for RHI
What's your current system?  Gas or oil?  And what is the current heating and HW numbers from your EPC?
JulianC
(@julianc)
Hi Kuba
I think it’s all about getting several quotes and approaches. 8mm pipes are small to the radiators, but do they run all the way back to the boiler at 8mm? Or are the “main lines” 35mm or 28mm?  That’s eh here a good ASHP engineer would be able to advise. As KevM says, we have just had an ASHP fitted. 10mm pipes to the radiators. But early days - just over two weeks of running so no data. UFH is best, but my wife said no to the upheaval.
The design of my system places a buffer tank between the ASHP and the radiator system. This alloythe ASHP to run at its pace / temp. And then we have a big, variable pump (nearly £500!) to push the water around the radiators. I had watched videos and heard concerns about noise from a higher pump, but we have not experienced that so far. The mantra for ASHPs is however lower temp and get the flow right.
 Kuba
(@kubak)
Thanks both for your thoughts!
@kev-m
  • We're still deciding on an architect, but most agreed that our extension will fit within permitted development. The permitted development rights for ASHPs in Scotland have some strange clauses, e.g. we're only allowed to install one heat pump, and it has to be removed immediately if it no longer works. Doesn't affect us, but I'm struggling to imagine situations where these would apply!
  • The Clean Homes Grant appears to be replacing RHI from next year, UK-wide. I'm not sure if it has been approved yet, but this is what I found on it: https://www.homeheatingguide.co.uk/grants-schemes/clean-heat-grants  You're right that Scotland might have different funding! There are definitely 0% interest loans than we can apply for to cover installation, but it also might be worth waiting to see what Holyrood decides after yesterday's election.
  • We've currently got a 24kW gas combi boiler.
  • Is it the heat and hot water demand numbers that you're looking for from our EPC? We're at 8998 kWh/year for heating and 2108 for hot water, with a predicted impact of -1934 once we install cavity wall insulation. In reality, our gas consumption over the last year was 13994kWh, but I suspect this was largely due to the cold winter and lockdown!
@julianc Downstairs they're 8mm all the way to the radiators. Upstairs we have a wider main line.
  • How much space does your system take up inside, including the buffer tank? Might have to consider a larger utility!
  • Do you know what the dB rating is for your pump?
 Kuba
(@kubak)
I thought I'd give an update on where we are, and maybe also give this thread a little bump in case anyone has any other thoughts.
Unfortunately we have had quite a large insurance claim due to escape of water, so plans for extending and heat pumps have been delayed a bit. On the plus side, the house is gutted, so once nerves settled, we took the opportunity to upgrade our plumbing. Our plumber discovered some pretty horrific things that the previous owners had done with the microbore, but now we have nice, new 15mm piping going to all of our radiators.
Getting a survey done next week to see if we can install cavity wall insulation - our house is pretty exposed to wind-driven rain, so we'll have to wait and see what they say about that. Not sure a heat pump would be viable without cavity wall insulation, I'd have to re-run the numbers.
After speaking to a few different installers, I have a pretty good idea of what needs to be done, so now I can weigh up the "should or shouldn't I" question. In theory it seems like a great idea, but what I'm lacking is evidence for houses of a similar style to ours. If anyone has any stories about retrofits to a 1970s semi-detached, I'd love to hear them.
