@morgan pretty poor. Although with the GHG having ended, I doubt they are in a rush
@batalto how long after accepting quote and paying initial deposit should I expect contact re the tech’ survey?
@batalto - when you say waiting RHI, what do you mean? I filled my RHI request on-line and pressed go. And the response came back approved in seconds. Set up my bank account payment and boom. All done.
Our first payment due now
@julianc because of the Green Homes Grant the documents need to be reviewed. I had to submit paid invoices to show how much I paid towards the system and how much the GHG covered. As an FYI my cost was £10,340 and the GHG picked up £5k of that for me. This reduces the RHI by the same amount (£5k)
Arh ok. Understood. I didn’t use GHG
Good luck with all the documents
Posted by: @morgan@batalto how long after accepting quote and paying initial deposit should I expect contact re the tech’ survey?
Update. Chased them and now have a tech’ survey booked in for 10th August.
As a note - RHI approved. £219 a quarter for the next 7 years, inflation linked at CPI - more than covers my costs
Good news @batalto Is your ASHP fully funded by GHB and RHI?
I have received my first quarterly RHI payment of £357
@julianc It will be yes.
£10,000 for the whole system
£5,000 GHG
£6,132 RHI (plus inflation)
£11,132 total from the government for the system
Be interesting to see what happens if the government go ahead as planned and replace the RHI in March next year with an upfront grant of up to £4,000.
£11,132 vs £4,000 is quite a big difference.
I assume the current RHI is probably unaffordable for the government as the number of installations ramp up.
@jeff seems to me like the GHG is just being replaced with a grant £4k less and the RHI is being scrapped. My cost profile would totally change and probably make the ASHP not worth it - unless the price of electricity changes to a much lower base. As is I'll make money and my cost should also reduce due to my solar and batteries
- 2,104 Topics
- 46.3 K Posts
- 96 Online
- 3,393 Members
@jamespa Heat Geeks did a full survey (although as the ...
By Matthew_W , 2 hours ago
@comfortablehomeseeker I have the usual combination of ...
By downfield , 8 hours ago
By seatonian , 8 hours ago
By Toodles , 10 hours ago
By JamesPa , 15 hours ago
By ASHP-BOBBA , 1 day ago
By EcoBaker , 1 day ago
By Bart , 2 days ago
By SUNandAIR , 3 days ago
By ChandyKris , 4 days ago
By rossowheels , 5 days ago
