A few pictures of where we are at the moment - Need to tidy up those battery wires and ethernets (they are way too long)
Very tidy Midea installation
@batalto, looking good.
New tank is in the loft - it fits!
@batalto, excellent. Do you have any photos?
Guys came back today to finish off the lagging and tidy up a few areas. Changed out the expansion tank from 18l to 25l. Not really a lot else to see except the services cupboard with all the meters and what not
Boiler cupboard (boiler doesn't work anymore!) - quite messy with old and new pipework. Anything unlagged is old (I assume?!)
Looks good. Why did you keep the boiler?
Just left it for the time being. I'll probably get rid next year after we've had the winter. It's all disconnected and just a lump on the wall for the moment
Solic now replaced - all working and diverting now. A bit of extra free energy for the tank
Next step - RHI application has been placed. Awaiting the process
Still awaiting contact by JL Phillips to arrange to carry out the full technical survey having accepted their quote.
- 2,118 Topics
- 46.5 K Posts
- 33 Online
- 4,522 Members
By Mars , 9 hours ago
@adamk what a shambles. Can you share some pics of the ...
By JamesPa , 13 hours ago
So the manual is correct and looks fine to me, to abbre...
By ASHP-BOBBA , 19 hours ago
By Transparent , 20 hours ago
By normpang , 21 hours ago
By ASHP-BOBBA , 1 day ago
By Burtis , 5 days ago
By JamesPa , 5 days ago
By Old_Scientist , 6 days ago
By Lucia , 7 days ago
By Ashfp , 7 days ago
By Mars , 1 week ago
