Adding underfloor heating
We currently have an ASHP installed, which was fitted with our existing radiators and one zone for both upstairs and downstairs. We are currently building a small extension (12 sq.m.), and we want to put underfloor heating in it. We also intend, at a later date, to replace the downstairs radiators with underfloor heating, possibly in the next 5 years.
My question is, how should the plumber add underfloor heating to the extension, given (a) the small area currently, and (b) the plan in the future to put UFH all through the downstairs? Is this something that any plumber can do, or do we need to go back to the original installers?
ASHP: Mitsubishi Ecodan 8.5kW
PV: 5.2kWp
Battery: 8.2kWh
if your ashp has hydraulic schematics for these types of install (vaillant for example) then copy those exactly. Otherwise:
The plumber should use close coupled Ts on the return line to take a parallel circuit to the UFH mixer/pump station. They should use an Ivar unimix3 blending valve (unless your your rad sizing was done to a suitable ufh temperature such as 35 degrees) because these are suitable for blending down low flow temps.
Posted by: @hughfif your ashp has hydraulic schematics for these types of install (vaillant for example) then copy those exactly. Otherwise:
Thanks so much, that's really helpful!
PV: 5.2kWp
Battery: 8.2kWh
@scrchngwsl I can't advise you on the technical aspects of it but can give you my opinion after carrying out similar works.
We were adding an extension and switching to a heat pump. We had specified ufh in the extension but mid works asked for a quote for the existing concrete floors to be removed, insulation and ufh to be retrofitted downstairs - approx 85sqm. The quote came back as €12k which was too much so just went for the kitchen and wetroom shower for €5k.
We are in about a year and recently switched electricity providers and went for a smart tariff with a cheap rate for 3 hours (2am - 5am). We now heat the ufh to 22 degrees overnight and those rooms don't need any more heat during the day.
- 2,772 Topics
- 65.3 K Posts
- 1,410 Online
- 7,174 Members
Grant R290 DHW Cycle Interuption
I have just had a Grant R290 9Kw HP installed to replac...
By Steam Powered , 54 minutes ago
Posted by: @batpred There´s another aspect that coul...
By Rob of York , 3 hours ago
By Mars , 14 hours ago
By Jimcub , 15 hours ago
By JamesPa , 17 hours ago
@jamespa My RFQ went out to 20 companies via email; in ...
By Toodles , 17 hours ago
By Prunus , 18 hours ago
Hmmm. We have 500sq metres here (including some very hi...
By Carpenterstation , 19 hours ago
Thank you @majordennisbloodnok – that means a lot, part...
Have you looked at the Nibe website? They list their ap...
By Lizzie , 2 days ago
By Papahuhu , 3 days ago
By Batpred , 4 days ago
By Rob of York , 4 days ago
