6 Red Flags to Avoid When Considering a Heat Pump Installation
@jamespa it is a good idea, but not easy as you say. We actually have something along these lines scheduled in for recording next week Friday for the podcast.
This article highlights important factors to consider when installing a heat pump. Identifying red flags, such as poor sizing, improper installation, and lack of maintenance plans, ensures you avoid costly mistakes and achieve optimal system performance.
Posted by: @gt22If I had a new ASHP installed I would still have to have a hot water cylinder. I watched the relevant video on this site. But I don't need any buffer unit.
Can I get clarification on this point.
Can the ASHP External unit, supply heat for Central Heating radiators or UFH at one temperature and one set of F&R pipes and do that supply directly? Bypassing the cylinder?
Or have I got that completely wrong and need to go away and do some serious reading? 🤔
Posted by: @nogotonyPosted by: @gt22If I had a new ASHP installed I would still have to have a hot water cylinder. I watched the relevant video on this site. But I don't need any buffer unit.
The ASHP, just like a boiler, can supply water at only one temperature at any time. So it switches between space heating and DHW. There will be one set of F&R from the heat pump, which splits into two sets at a diverter valve.
The reason that boilers (as we set them up in the UK) can do both simultaneously is that they run the heating at a high flow temperature, resulting in both reduced comfort and a 10% increase in energy consumption and therefore cost. Boilers, like heat pumps, are actually best run at a low temperature with weather compensation (best both for comfort and cost!), but in the UK we rarely do this, unlike some more enlightened countries in mainland Europe.
Read your Red Flags with interest. Presently tweaking my system and getting the flow temperatures down as for the past 8 yrs It has been set at 50c
Currently adjusted lockshield valves to balance the Rads and brought the flow temps down to 44c without realising musch difference . I notice you suggest 38c which is quite low to what I have had it set but willing to try.
Can I ask what flow speed can my system run at , I notice there is a graduated glass viewing setting.
I also have a buffer tank in the system which I have only discovered from this forum may not be needed . However its there and reluctant to change , due to cost.
Hypothetical House Design
4 months ago
Why Buffer Tanks & Low-Loss Headers Can Sabotage Your Heat Pump's Efficiency
9 months ago
Currently viewing this topic 6 guests.
- 2,813 Topics
- 66.6 K Posts
- 4,459 Online
- 7,223 Members
By SusannaSaunders , 7 minutes ago
@susannasaunders The high end Daikin Ururu Sarara A2...
By Rob of York , 9 minutes ago
By Mars , 38 minutes ago
@jamespa The complexity ensures employment for all thos...
By Toodles , 42 minutes ago
By Toodles , 7 hours ago
I didn't throw it away. Is there a way to determine wha...
By bobflux , 8 hours ago
By bontwoody , 1 day ago
By Rob of York , 1 day ago
I think you're right! 🤨
By Chilli304 , 4 days ago
By Rob of York , 5 days ago
