As you say, nothing appears to be changing dramatically. Though I fail to understand how your home is maintaining an indoor temperature of 18C, with an outdoor temperature of 6C.
Now try setting your system in fixed LWT mode with a setting of 35C.
Â
@derek-m I've no idea. 🤣
I turned the system off for the Octopus saving session at 17:30 room stats showing 18. Went out and came back at 20:30. Turned back on and room stats were at 17.5. Not sure if you need that info but just in case it's relevant.Â
I'll have to work out how to set fixed lwt mode. I'll do it tomorrow. Thanks again.Â
@derek-m overnight it was 4 degrees and it has struggled to keep 18. The house is at 17.5 this morning. COP is down to 3.3 and it's using more power and running for longer. 15.6kw yesterday 13.3hours operation time (that's with turning off for 3hours)and a generation of 51.7.
Posted by: @craig1980Is this what you mean?
Â
Yes, that would appear to be the correct method. Try running with a LWT of 35C and see how the system responds, and if it stops the 20 second off periods.
Â
Okay, that's done. It was already on standard temperature "water outlet". Could that have been an issue?Â
How is the system operating now? Is it still running 8 mins on and 20 secs off?
What is happening with the room and radiator temps?
What are the flow and temperature readings etc?
Changing the way that the system is being operated is to try to find what is causing the 20 seconds shutdown.
So, it appears to run constantly but at quite high power usage of 1.9kw instantaneous power.Â
Rads feel warmer to the touch but room temp stays at around 18 according to room stats and thermometers that I used for radiator temps.Â
Outside temp is 6.0 according to wired remote.
Water outlet 35.4
Indoor 21.5 (remember, this is in the airing cupboard with the UVC).Â
Posted by: @craig1980So, it appears to run constantly but at quite high power usage of 1.9kw instantaneous power.Â
Water outlet 35.4
Now measure the top and bottom temperatures on two or three relevant radiators, and the flow rate and temperature readings from the information screens.
Â
- 2,208 Topics
- 48.7 K Posts
- 85 Online
- 5,868 Members
RE: The Hidden Secret to a Successful Heat Pump: Pipe Size Matters
@davidnolan22 I genuinely do not know the answer, unles...
By ASHP-BOBBA , 5 minutes ago
@transparent my reading of the report P28 (and probably...
By Judith , 1 hour ago
RE: 4 Year Ongoing Heat Pump Battle With Poor Heat Pump Installation
@jamespa Oh, I know some that are good and some not so....
By ASHP-BOBBA , 1 hour ago
RE: Samsung Heat pump with Yonos Pico circulating pump running all the time
I don't know how many pumps you have but I guess it's o...
By JamesPa , 2 hours ago
That's just human nature unfortunately, not special to ...
Absolutely. That’s one of the reasons I wouldn’t want t...
By Majordennisbloodnok , 3 hours ago
@editor The season to start inviting prospectives to ‘V...
By Toodles , 9 hours ago
@bontwoody how long has it been now since you started t...
By Mars , 9 hours ago
Yes, over the last few days I've been keeping a very cl...
By Steelbadger , 9 hours ago
Absolutely. I am one of those members and I most certai...
By Majordennisbloodnok , 11 hours ago
@darrell-p There's another new Forum Member, @wully who...
By Transparent , 11 hours ago
We've had a slight glitch with our security software fo...
By Mars , 14 hours ago
RE: Samsung Heat Pump – Can't Activate TW2 Pipe Sensor (for Delta T Control)
If you do suggest you consider repurposing it as a 2 po...
Fully agree with @cathoderay. My journey took 2 years ...
Tim, Yes ChatGPT thought I could get another...
By Mike Patrick , 1 day ago
RE: Enabling WiFi: Samsung ASHP on Smart Things App
No problem, @richdorm; glad it helps.
I do already have the same basic setup, all room influe...
RE: IVT Greenline high pressure switch and electrical cassette errors
OK. You dont say whether it is from the feeds to/from ...
