MCS heat pump pre-sale information and performance calculation
Posted by: @johnrI would agree that knowing the peak daily gas consumption is useful, but not the peak hourly or half hourly as the underlying philosophy for efficient heat pump operation is to keep trickling heat into the building at approximately the rate which balances the heat loss. Sizing a heat pump to give a blast of heat means a more expensive heat pump operating at a higher and less efficient temperature.
As I mentioned, a short duration analysis seems to be adequate, but I only discovered after analysing the historical data first. 'Blasts' of energy are best avoided, I agree. I believe that the thermal mass of the fabric of the house comes into play here - internal brick walls rather than framework partition walls will help - and any potential problems will be mitigated by weather compensation. Some pragmatism may be required and an acceptance that on a handful of unusually cold days it may be necessary to add some clothes or supplement the heating. The challenge is to find the 'sweet spot'.
- 2,766 Topics
- 65.1 K Posts
- 1,438 Online
- 7,169 Members
I agree. However I would also (primarily) expect that ...
By JamesPa , 8 hours ago
You should (almost) always reject having a buffer, by w...
By JamesPa , 11 hours ago
By Toodles , 15 hours ago
@majordennisbloodnok I do sympathise. On the original...
By springswood , 17 hours ago
No, but the heat pump must be capable of delivering a S...
By JamesPa , 20 hours ago
Sorry to hear about the problems, its going to be somet...
By JamesPa , 22 hours ago
By bobflux , 1 day ago
By cathodeRay , 1 day ago
RE: Vaillant Arotherm Plus 7KW need a service on it
booked it with Vaillant. will use them until i can find...
By AdamK , 2 days ago
I have seen it stated that the declared calorific value...
RE: Two heating zones to one zone
@transparent Many thanks. The garage is fairly well ...
By Profzarkov , 3 days ago
RE: Vaillant Aurotherm - Heater Wire Position
Ah, good point. I need to check if this was installed i...
By Batpred , 3 days ago
@batpred thanks for getting a copy. Appreciate the supp...
We have a 6.56kW solar PV system (16x 410W panels) inst...
By Rob of York , 4 days ago
