A Call for Fair and Legal Heat Pump Installations in the UK
Please consider responding to this consultation if you believe that the installation of heat pumps should be legalised in the UK.
- The Department of Energy and Sustainable Net Zero (DESNZ) authorised the Microgeneration Certification Scheme (MCS) to establish the regulations for Permitted Development (MCS 20).
- MCS has stipulated in their standard that heat pumps must be installed by MCS-certified contractors to comply with legal requirements.
- This regulation effectively makes it illegal for anyone to install a heat pump without obtaining planning permission.
DESNZ initially intended for MCS to develop "a noise standard." Under this guideline, if heat pumps were sufficiently small and quiet, they could be installed under Permitted Development. However, MCS seems determined to be the sole standard authority, restricting heat pump installation exclusively to MCS members. They have added extra requirements to the noise standard, effectively barring non-MCS installers from utilizing Permitted Development.
This approach is problematic. Planning Permission typically concerns visual and noise impact, not the qualifications of the installer. The appearance and sound output are what matter, not who installs the equipment. The Planning Rules for heat pumps should reflect this principle. MCS needs to eliminate the inadvertent requirement that effectively restricts Permitted Development to MCS members.
Your input in the consultation is crucial to clarify this situation. It will help determine whether this is an unintentional error or a deliberate attempt by MCS to monopolise heat pump installations.
Unfortunately, the MCS consultation form does not provide an option to suggest simplifications or streamlining of this process. Therefore, it's recommended to email your response directly to MCS, requesting confirmation that your input is acknowledged, despite not using the official form.
Addressing this issue is vital. If the regulation is intentionally restrictive, it's no longer a mere oversight but an abuse of the authority granted to MCS by the government.
Free UK shipping.
📗 Heat Pumps Explained
📘 From Zero to Heat Pump Hero
🛠️ Bodge Buster
New to heat pumps?
so they are consulting on certain questions, but they aren't actually asking the question that we think they should ask, and the idea is for lots of people to respond to the consultation, challenging with a specific question along the lines of "I think you need to change this part of the standard as well"
for the avoidance of doubt you are referring to MCS020 clause 3.1(b) right?
@iancalderbank, valid point.
As a complete aside, I couldn’t help notice “41kWh of Battery storage (3x Powerwall 2)” in your signature. That is mightily impressive.
Free UK shipping.
🛠️ Bodge Buster
New to heat pumps?
There's a related change in regulations which will affect what MCS may do in future.
During 2024 there will be a new Independent System Operator and Planner (ISOP, aka Future System Operator) who will be responsible for operating all energy networks in GB (excl N. Ireland). They will also take on the role for advising HMG, and must implement strategies which result in us attaining Net Zero by 2050.
To provide regional input and democratic accountability, there are to be 14 Regional Energy Strategic Planning bodies (RESPs), whose remit and responsibilities are currently subject to an Ofgem consultation.
Note that the word 'Plan' occurs within the role of both the ISOP and RESPs.
I foresee that the ability of MCS to dictate matters regarding planning will need to be curtailed in favour of the ISOP who is actually required to deliver the 2050 objectives, which include Net Zero domestic heating.
It is also increasingly unlikely that a Local Planning Authority (LPA) can be expected to appraise Applications which are substantially related to energy. It matters not whether that's a homeowner wanting a heat pump or an entire offshore wind farm. On which point, have a look at this announcement from North Devon Council on 19th Dec, who are grappling with a highly contentious planning application to bring ashore an electricity cable through an SSSI:
An LPA simply doesn't have the time or experience to handle applications on such a wide range of size and differing technologies.
Perhaps there needs to be a new approach whereby any Application which is substantially energy-based must be assessed by both the LPA and the regional RESP. They could then issue guidance under which the majority of householder HP Applications can be granted consent under Delegated Authority, regardless of whether the installation is to be undertaken by an MCS-accredited company, or is DIY.
I've recently submitted evidence to the Commons Select Committee on ESNZ, detailing thirteen reasons why current planning regulations are inadequate to accept/reject energy applications.
I can post these here if you wish.
We live in a democracy. Whilst Parliament seems to be in the mood to devolve energy planning and implementation to us, then the least we should do is to respond to the consultations and tell them what we require in order to achieve Net Zero.
I must say, the MCS020 seems to me quite a straightforward calculation as it is set out at present. It takes 3 minutes to complete. There is room for improvement and clarity on some elements but I can't see a case for simplification. Noise can be a serious issue and installers need to take time to properly assess it. I think at times calls for simplification are founded in a feeling that the test is s bit of a nuisance and frustrating to have to plan round rather than embracing it and avoiding placement where issues could occur.
If it is the content/calculations that are flawed, that's one thing (if the DENSZ research is anything to go by, these need to be tightened), but anyone could do the calculation.
I do think that if another body other than MCS is able to certify then standards must be aligned & the bodies must be brought more into public accountability eg FoI etc. Overall MCS compliance is a requirement of the Town and Country Planning Act and that's the law *inserts picture of John Thaw in the Sweeney*.
- 2,783 Topics
- 65.6 K Posts
- 5,779 Online
- 7,187 Members
Theres comprehensive instalation and service manuals (I...
By Singlespeed , 8 hours ago
There is now a new Secretary of State for Energy Securi...
By Transparent , 9 hours ago
RE: Do I add Air Con or MVHR to existing A2W ASHP?
@rob-of-york Looks like an impressive bit of kit. Just ...
By Batpred , 9 hours ago
The idealist in me says pioneers in this space should b...
@ashp-bobba, I thought it was an interesting parallel. ...
By Mars , 12 hours ago
RE: Adding additional Solar Panels to a DC coupled battery system
@transparent No it was my baby, entirely delivered by m...
By bontwoody , 14 hours ago
Ah, that makes sense when a combi is in place. The boil...
@bobflux Thanks, that gives me something to check the i...
By Paul1098 , 1 day ago
For Powerwall calibration, avoid forcing repeated deep ...
By EnergyStorageTech , 2 days ago
By bobflux , 2 days ago
By Andris , 4 days ago
By Papahuhu , 5 days ago
By Batpred , 5 days ago
By Rob of York , 5 days ago
