Huwaei Luna 2000 Charge and Discharge Limits
I have a Luna 2000 5kWh battery module and have found it difficult to get any definitive advice on how so set up its charge and discharge limits.
The advertising blurb states its uable capacity as 5kWh but Im wondering whether it is wise to charge 0-100% from a longevity point of view.
At present I have it set to 20%-100% and last winter had it 5%-100%. Obviously i would like to get the maximum I can from it but also prolong its life as much as possible.
Any ideas? thanks
10kWh DC coupled battery
No suggestions for this?
If we talk generally about LiFePO4 batteries and I wanted to get the most capacity I could without compromising the batteries longevity would 20%-100%, or 10%-90% be better? could I go to 5%-95% without problems? Thanks in advance
- 2,764 Topics
- 65.1 K Posts
- 1,735 Online
- 7,169 Members
I think not but have now added the cloud coverage weath...
By Batpred , 5 hours ago
@judith Thanks very much for this! My room by room calc...
By jon , 9 hours ago
RE: Vaillant Arotherm Plus 7KW need a service on it
I think that is outrageous even if I suspect not unique...
By Batpred , 10 hours ago
RE: Two heating zones to one zone
@transparent Many thanks. The garage is fairly well ...
By Profzarkov , 13 hours ago
RE: Vaillant Aurotherm - Heater Wire Position
Ah, good point. I need to check if this was installed i...
By Batpred , 19 hours ago
Posted by: @jamespa At this point its probably worth...
By Rob of York , 21 hours ago
@batpred thanks for getting a copy. Appreciate the supp...
We have a 6.56kW solar PV system (16x 410W panels) inst...
By Rob of York , 1 day ago
RE: Where heat loss surveys seem to go against practical reality
@cathoderay @jamespa I've managed to get some nice re...
By Rob of York , 3 days ago
RE: 7kW EV Charger Options Advice
Doh, not sure that I was thinking straight there, less ...
By Rusty , 3 days ago
Thank you @trebor12345
By rgabor , 3 days ago
Panasonic Free Multi Z and Etherea Internal units.
My prospective installers have suggested the Panasonic ...
Great. You just need to find a way of cranking up your...
We had two heat pumps installed without Govt funding. H...
By Rob of York , 4 days ago
