Posted by: @jeff[....] a mandatory annual check of your solar pv and batteries etc. with someone suitably qualified.
[....]I think it is only fair the cost of any check falls on the household that has the equipment installed, just like i pay for an MOT on my van.
Do you think there's a possibility that the public might perceive this as 'an unwarranted tax' on those who trying to combat the energy crisis by exporting solar power for others to use?
It's what Sir Humphrey Appleby would call a "courageous" proposal.
There are local government elections in May.
Perhaps you could stand as a candidate on that platform.
It might be one of those issues that really resonates with the electorate... 😉
Posted by: @transparentPosted by: @jeff[....] a mandatory annual check of your solar pv and batteries etc. with someone suitably qualified.
Perhaps you could stand as a candidate on that platform.It might be one of those issues that really resonates with the electorate... 😉
Not the sort of thing that will ever be in a election pledge.
Also irrelevant to the vast majority of the population given the current number of people having or considering batteries. We only have circa 4% with solar PV so it will never be in any manifesto.
I was being serious though, the risk of well intentioned DIYers etc installing dodgy systems isn't a laughing matter... You are relatively experienced but are still learning. You have mentioned before about regulation.
It scares me that people might play with solutions with sub standard kit and designs.
Not everyone will be as careful as you, i suspect most won't be a thorough... There will be an awful lot of not great kit people can import from China etc.
I find it worrying personally. I don't view it as a tax. I don't view my MOT as a tax.
Do you think the current regulations and oversight around storage in the home is sufficient @transparent?
Interesting Octopus Outgoing doesn't need solar PV, so perhaps Octopus Flux has some flexibility?
Do I need to have solar, or could I take advantage if I have home batteries and/or V2G?
Outgoing Octopus is best for homes with significant renewable generation, but you don’t HAVE to be generating energy to benefit.
Join Outgoing Octopus and use home batteries (or your EV battery, if you've got hold of a vehicle-to-grid charger...) to take advantage of low consumption prices on our Agile tariff and high export rates on Outgoing Octopus. It’s a balancing act.
Store electricity at times of the day when the Agile prices are super low or even negative (on December 8 2018 Agile dropped to -2.31p per kWh). Then export from your battery when energy on the grid is most in demand, and most expensive. Not only are you powering your home with cheaper stored energy, but supporting the grid when energy is in high demand, and making money off anything extra you export.
If you’re exporting more energy than you’re using, you might even get your Octopus bill into credit. And we’ll even refund the cash if you wish. It’s worth remembering, though, your home will consume battery discharge first before sending the surplus to the grid).
Yes @jeff sometimes methinks I jest too much. But I occasionally in a few cartoons and light-hearted comments to retain the attention of others who may be browsing here amongst the technical discussions.
Coincidentally, I have just responded to a well-intentioned DIY end-user over here in a discussion on the PureDrive II storage battery.
I like the MCS approach, but it wasn't conceived as a mechanism by which export payments should be authorised. So it's bound to throw up anomalies when Energy Suppliers are required to use it to authenticate an application for SEG.
Nor do I think installers would be interested in undertaking annual MOT-style audits of pre-existing installations, certainly not for that level of remuneration (currently £55).
They have a backlog of orders to fulfil and aren't looking for additional administrative tasks.
The situation would change if house insurers required audits of course. But I think that's a long way off yet.
Step 1 would probably be a health-check for generation/storage equipment in rental properties, rather than those which are owner-occupied.
Dragging us back to the plethora of Octopus ToU tariffs which are emerging, there is a likelihood of these instigating an upsurge in home-owners looking for storage solutions.
However, that might not be matched by an equivalent level of interest in export potential.
What I'm reading into Octopus' Flux Tariff is that they have calculated levels of payment from which they can deduce the public appetite to receive income from exporting electricity.
They're obviously not able to create a mathematical model based solely on the meagre amounts payable under the SEG alone (5p per kWh). 🤔
Octopus, and other Energy Suppliers, would clearly prefer to buy-in electricity from their customers during times of peak demand, rather than leave themselves exposed to the higher rates and speculation of the European Wholesale Market.
If the general public were more aware of mechanisms for electricity storage with zero export, then that's what I think they'd opt for.
It's the lack of knowledge which holds back that market.
Posted by: @jeffInteresting Octopus Outgoing doesn't need solar PV
Pedantry alert.
Octopus state that they require MCS certification of the system. The MCS front-page does not mention EV chargers, so I am not sure how one could used Octopus Outgoing with an EV to charge off-peak and discharge on-peak.
I also suspect there is some level of flexibility, although I'd be wary of making large purchases based on the electricity supplier's whim.
Agreed, i don't think an MCS (or equivalent) accredited company would be interested in cheap MOT audits right now, perhaps ever, simply because of their other demand on installations
It could be an electrician could be trained to do an electrical safety audit of a battery setup and check if anything obvious had been swapped or anything was dodgy. This would be a larger cohort of people. They would not have to be as experienced as an MCS company. We manage it with MOT testers. We have very few home batteries in the UK so that might not need many people now. The price point is interesting, but it is what it is, safety isn't free.
Rented property would be good in the same way we have gas safety checks for £45 from some companies. Not mandatory but Electrical Safety Checks on domestic properties start at around £69.
I appreciate i am perhaps being unrealistic... the DIY market does fell a bit wild west though at times. Perhaps it is such a small cohort of people, it shouldn't be a priority.
Anyway i doubt anyone would take forward my idea 😊
Hi, if you have a FlexiOrb certificate for your solar installation simply attach that instead of the MCS
I did ... and with the help of an email to smart@octopus.energy 😁
Question.
I have just moved to this this tariff. I would like to compare this to Agile import and export as I can shift my main usage of electricity.
Unfortunately I could not look up previous data on daily prices for some reson. It just doesn't work. If some could put here a screen grab of let's say last week's prices. I would relly appreciate that. This way I can have a little look at the numbers for outgoing and importing half hour tariffs and see if this would be better for me than the flux. I hope this makes sense.
Thanks again Andris
LG Therma V 16kw ASHP
Underfloor heating + Rads
8kw pv solar
3 x 8.2kw GivEnergy batteries
Manual changeover EPS
MG4 EV
Posted by: @andrisQuestion.
Thanks again Andris
https://energy-stats.uk/download-historical-pricing-data/
This.is the page that doesn't work for me. Can u take a screen shot of agile for me please.
@jeff thanks I tryed both but don't work unfortunately. I just need I day of outgoing and incoming tariff recently. So if u would be so kind to take a creen shot that would be enought for me. Thanks.
- 2,418 Topics
- 54.8 K Posts
- 338 Online
- 6,098 Members
RE: How to use my Hanchu battery storage for home without it feeding back into the grid?
@countryman-helmsley In that case is there a button ...
By IRMartini , 57 seconds ago
RE: Heat pump not reaching flow temperature
@jamespa @johnd just spoken with our installer who also...
By DaveC , 20 minutes ago
Thanks. Thats pretty much my intended route i...
By JamesPa , 59 minutes ago
RE: Is it normal to use power from the grid when running off the battery?
The Solis S6 has various modes of use. I currently have...
By Batpred , 1 hour ago
RE: Is my Samsung gen6 outside air temp sensor missing a sheath/sleeve?
@papahuhu I would definitely check the upstairs radiato...
By bontwoody , 1 hour ago
RE: R290 and Foundation Air Bricks
I appreciate that the risk is probably proportionate to...
By L8Again , 2 hours ago
RE: Ideal HP290 14kW ASHP - how to optimise
Great. It’s not bad is it, though I agree it may repres...
By Davesoa , 2 hours ago
RE: Water outage in the the south-east
1: There are homes at the Lizard peninsula, SW Cornwall...
By Transparent , 2 hours ago
RE: Ecodan Pump Issues… Circulation pump turns off when heat pump compressor turns off
@f1p apologies, you are absolutely correct
By Patch321 , 2 hours ago
Area under graph is indeed a valid approach and the one...
By JamesPa , 2 hours ago
RE: Reliable, easy to use home battery options
However, see what I've just posted here about these (ch...
By Transparent , 3 hours ago
RE: Installer Fitted 9kW Instead of 11kW Heat Pump and Changed MCS Paperwork - What do I do?
Another good bout of cold weather should test whether t...
By JamesPa , 5 hours ago
RE: Samsung E101 Error Message and my ASHP Efficiency
@johnnyb amazing that the our forum is serving its purp...
By Mars , 16 hours ago
Best option for controller upgrade? - Grant Aerona
Fairly new heat pump owner - Grant Aerona 3 10kw - and ...
By Topher , 17 hours ago
RE: Daikin Wireless Thermostat
@toodles Yes. British Gas seems to have done an exce...
By Bash , 18 hours ago
Just a brief update to keep things transparent. Secti...
By DREI , 21 hours ago
I continue to receive emails from homeowners sharing he...
By Mars , 22 hours ago
@mrfield, welcome to the forums. Please go here and ...
I did not hear back from the tech team. (Assume they ar...
By swwils , 1 day ago
In the Home Assistant firmware the data points...
