Posted by: @editor@Jeff, that's good news. It'll be interesting to see what happens over the summer, and whether October will lead to positive news when the tariff cap is revisited.
I'm still subscribed to the weekly local oil club newsletter and I see that kerosene went up again this week.
The price cap will be released by ofgem around 6th August based on the previous 6 months costs. Hence quite a bit of increase is already backed into another rise.
Still a lot of uncertainty about what the government and ofgem will do to tweak the actual mechanism.
Just checked Octopus Go - Latest rates are 7.5p off peak and 34p on peak. Thats eye watering.
Makes my batteries (11.3kwh of useable) worth £1,098 if I fill up with off peak every day. Let alone any solar benefits
Posted by: @bataltoJust checked Octopus Go - Latest rates are 7.5p off peak and 34p on peak. Thats eye watering.
Octopus still seem committed to funding Go as a loss leader according to statements this year
"Octopus raised its rate from 5p late last year, but says it’s committed to low EV tariffs as a ‘loss leader’ to encourage adoption."
EDF are still offering 4.5p for 5 hours which may be better for some.
I know someone using the EDF rate for charging and the Octopus Outgoing Agile for selling their excess back to Octopus.
Former Bulb boss still getting paid £250,000/year… that’s kinda crazy.
https://www-bbc-co-uk.cdn.ampproject.org/c/s/www.bbc.co.uk/news/business-61149569.amp
Posted by: @editorFormer Bulb boss still getting paid £250,000/year… that’s kinda crazy.
Unfortunately this is almost certainly cheaper than the alternative of a partner level resource from one of the consultancies being charged out at several thousand pounds a day plus expenses. Plus they would want others with them.
I recently received a reply from Ofgem, when I questioned why the standing charge for electricity had been increased by approximately 100%. Apparently £68 of the £103 annual increase is to pay for the failure of all these electricity providers, though it would appear that the directors of some of these companies have done quite nicely out of the process.
@derek-m, that’s crazy. It looks like Bulb’s failure is going to cost the government around £3 billion. I genuinely have massive concerns about how this is all going to end, with tens (if not hundreds) of thousands of people being forced into fuel property in the coming 12 months.
@editor The government probably isn't going to print more money to cover this when it can raise it through standing charge levies, so it's going to cost us (collectively) £3bn, whether we fell for bulb or not!
@mjr where do you think the government gets its money from? It doesn't pay for things, we do via tax. Or we shunt it into borrowing and our kids do.
I think Thatcher said "there is no such thing as society" - society doesn't do anything to anyone, we are society.
@mjr QE was effectively a printing press in all but name. The government borrows money from the Bank of England which it then "owes" back to itself as the state owner of the bank. Amazing wheeze. Sadly my bank refuses to do the same for me. Perhaps I should start my own bank.
Posted by: @mjrThe government [....] can raise it through standing charge levies
It's true that the recent rises in standing charges have been underpinned by the need to re-fill the coffers from the 19 Energy Companies whose customers were rescued by the Supplier-of-Last-Resort scheme in 2020. What then puzzles me is why there is such a wide variation in those charges across the Regions.
- 44 Online
@jamespa Thanks. Yes, its a bit sad so many of these jo...
By ASHP-BOBBA , 2 minutes ago
I managed to find a perfectly good new but 'last years ...
By cathodeRay , 8 minutes ago
By dgclimatecontrol , 2 hours ago
My heating isn't 'ON' yet, although it is firing up in ...
By Morgan , 2 hours ago
@damonc If the heat pump controller is in a suitable ar...
By HCas , 3 hours ago
If that's the case then you are right to be sceptical, ...
By JamesPa , 6 hours ago
By Lucia , 9 hours ago
By ASHP-BOBBA , 20 hours ago
By Tim441 , 1 day ago
By Transparent , 1 day ago
By HCas , 1 day ago
By jamespetts , 1 day ago
By GrahamF , 2 days ago
By immunity , 2 days ago
Just done your survey!
By Judith , 3 days ago
