DHW Efficiency
Do you need the DHW tank as high as 50°C @egp01 ?
Have you tried running it at 45°C for a few days to see what effect it has on the COP?
@transparent, that’s a bang on suggestion. 45C DHW tends to be the sweet efficiency spot for most heat pumps.
Posted by: @editor@transparent, that’s a bang on suggestion. 45C DHW tends to be the sweet efficiency spot for most heat pumps.
@editor is that correct? My installer set DHW to 50c and suggested it remain there. I wonder if a 5c difference will leave me with sufficient hot water. (250L tank). I might have to give it a try because my COP barely gets up to even close to 3!
Yes, please do try it @morgan and let us know what you find.
How long would you need to conduct such a trial in order to know the effect on COP with a reasonable level of accuracy?
Can you also say if you're running an anti-legionella cycle, and at what intervals?
That would also decrease efficiency of course, and make it unclear whether you setting the DHW down to 45°C is a 'fair test'.
There's a big difference running anti-legionella on a 250l tank and a 180l tank for example.
So many variables to consider...
... but please tell us what you can.
@transparent I am running an anti-legionella cycle (60c), but I need to remember how to get to it again to see the intervals. But that needs to remain, doesn't it?
Well it depends on what we're going to consider a 'fair test'!
Does the phrase "my COP barely gets up to even close to 3!" include operating the anti-legionella cycle?
Assuming the AL cycle consists of
- the ASHP taking the DHW tank to 50°C
- a 3kW immersion heater switching full-on until the tank achieves 60°C
- the immersion heater cycling off/on to maintain the 60°C for 10-mins
then that could use an enormous amount of electricity for a 250-l tank.
Depending on how well insulated is the tank and surrounding pipework, it would also take about 90-mins to complete the cycle.
See my calculations in this topic about Heat Batteries.
@transparent Yes to questions 1 to 3. Also, yes to the phrase "my COP barely gets up to even close to 3!". It does include the anti-legionella cycle.
- 2,364 Topics
- 53.6 K Posts
- 134 Online
- 6,029 Members
Yes. In addition or instead. The point us that trv b...
By JamesPa , 11 hours ago
RE: ASHP sizing - value of Heat Transfer Coefficient
@toodles Hi, my friend recently made a video about heat...
By HeatPumpMe , 16 hours ago
How long will your energy contract last?
Some heat pump tariffs don’t run as long as a heat pu...
@morgan They are unsupervised these days, can’t get the...
Exactly. We only need to compare conditions, to decide ...
By cathodeRay , 3 days ago
I found because I have very low heat loss I can set bac...
By RadWhisperer , 3 days ago
RE: Need Help Optimising My Rushed ECO4 Install: 12kW Bosch Heat Pump
Welcome @mickamills We too have an oversized 12kW Sa...
RE: My Powerwall 3 Consumes 3-4 kWh/Day in Self-Consumption: Is This Normal?
@caron I can confirm that the power usage of the PW3 is...
RE: Speedcomfort radiator fans
Thats true, but having tried (and succeeded) in constru...
@bash brilliant, thanks for the feedback
By energy9165 , 3 days ago
RE: Heat Pump Heats the House… But It’s Not Cosy. Emitter Changes or System Tweak?
@alastair There I was, feeling grumpy, he said “Cheer u...
RE: Grant Aerona: Is there a setting to keep the 2-port valve open during pump blockade
Depends on OAT. Mine cycles at OAT>10 and of course...
@transparent My conclusion is as you have noted, tha...
By Bash , 4 days ago
RE: Mitsubishi Ecodan R290 10kW performance
And to you too. Wishing you a very enjoyable festive s...
RE: External pipework insulation
They do? But that isn't apparent from the photos we'r...
@velcro welcome to the forums. Please feel free start a...
Daikin EDLA11D3V3 DHW Settings
I have a newly installed EDLA11D3V3 which I'm still get...
By Velcro , 4 days ago
@curlykatie did you get sorted with this?
By MickaMills , 5 days ago
