Opinions please on me putting a 2.5kW roof mounted turbine on my garage - am I mad?
I asked AI to analyse their documents and explain to me on this point.
It says
Retail Value Savings:
- The electricity generated by your share of the wind farm is credited directly against your electricity bill at the retail rate. This means that if you invest in enough energy to cover 4500 kWh per year, the savings on your bill would reflect the cost of 4500 kWh at the rate you would otherwise be paying to your energy supplier (e.g., 19p per kWh).
2. How It Works:
- Ripple Energy partners with specific energy suppliers who manage these credits. When the wind farm generates electricity, the equivalent amount is deducted from your bill as if you had consumed it from the grid. You effectively receive the full retail value of the energy you’ve invested in.
3. No Wholesale Rates:
- Since the credit is applied based on the retail value, there’s no impact from the wholesale market prices. You are benefiting directly from the electricity offset, meaning your savings are calculated at the same rate that you would otherwise pay on your electricity bill.
@gary thanks Gary.
The share offer document gives an estimated return rate of 6.3% and the calculations provided by the site are also different again from that.
confusing. But even still probably worth it at 6.55p. I’ll sleep on it, I think.
@marvinator80 did you ever pull the trigger in this?
- 2,102 Topics
- 46.2 K Posts
- 111 Online
- 3,388 Members
PS to above. I just looked again at the photo you post...
By JamesPa , 49 minutes ago
And we have it: DESNZ are now investigating the feasi...
By Lucia , 2 hours ago
@skyefarmer great you located the source of the issue a...
By Mars , 6 hours ago
By ASHP-BOBBA , 15 hours ago
By Mars , 24 hours ago
By downfield , 3 days ago
By Sune , 3 days ago
