[Sticky] Tell us about your Solar (PV) setup
@newhouse87 as much as you can fit south facing. Then west. But your installer should recommend orientation to maximise output
@newhouse87 South facing as much as you have space for would provide maximum production with the rest on west facing. If your finances would run to it, give serious consideration to installing battery storage which would allow for greater flexibility in terms of maximising use of solar energy to power your ASHP. Regards, Toodles.
@newhouse87 As @toodles suggests, it depends on whether you intend to install a battery and your split between home use and export. I have recently had 8 panels fitted on an (almost) easterly-facing roof and 6 on an (almost) southerly roof. Per panel, the energy output is slightly higher for those on the southerly roof but there is some shading from the early evening from trees to the west. In your situation, thinking only of roof placement and not where the energy goes, I think I would do as your installer suggests and fit 12 & 6. You will then have a single roof area remaining in case you wish to expand in future (I have bits of roof of various sizes for this purpose). As a result of my battery (13.5kWh) I have paid only standing charges since my equipment was installed.
By the way, that chimney is a nuisance.
Thanks for replies. The chimney wont interfere too much with the west panels as far as i can see. I wont opt for battery yet as prices coming down and i can sell any excess to grid for decent price at the moment. We used most electric during highest tariffs of 5-7 with cooking so west facing suits this. Did my theory of placing 6 west panels on small roof over sliding door rather then all 12 on big west roof make any sense, thinking that farthest reaches of west roof will get sun last and in winter might get v little. I could try get panels on small roof behind heat pump south facing but was worried about other roofs shading it and also told bigger strings of panels better rather then putting say 3-4 on small roof.
Your installer’s suggestion of 12+6 is the best suggestion. You can always add more blocks (with its own optimiser) later.
Aas a bungalow you avoid the bigger upfront and modifying costs of scaffolding so you can make changes fairly easily.
Batteries are coming down in price but you are missing out on the savings while waiting. There are threads on here about making good savings self building batteries if you want to make savings.
- 2,153 Topics
- 47.3 K Posts
- 12 Online
- 5,673 Members
Nice one @toodles... always appreciate your enthusiasm ...
By Mars , 5 hours ago
By bontwoody , 9 hours ago
@patrickvito We have had car dealers re-powder coat the...
By ASHP-BOBBA , 10 hours ago
By Alex , 10 hours ago
By GrahamF , 10 hours ago
By Morgan , 10 hours ago
By DREI , 13 hours ago
By Profzarkov , 15 hours ago
By GrahamF , 16 hours ago
By cathodeRay , 18 hours ago
By ASHP-BOBBA , 1 day ago
By DREI , 2 days ago
@bontwoody Maybe one for @editor to consider whether a ...
By ChandyKris , 3 days ago
