Buying a new EV charger
Posted by: @agentgeorge@batpred they should change their name to OhMy!
Absolutely, but they seem to make great youtube videos singing to the tune of an app with great UI...
They avoided my direct question about how I can use their charger using the API as a dumb socket...
We have continuous issues. The "app" no longer checks the car battery level and now it also does not charge when we need it to.
16kWh Seplos Fogstar battery; 8kW Solis S6-EH1P8K-L-PLUS hybrid inverter; Ohme Home Pro EV charger; 100Amp head, HA lab on mini PC
@batpred Inwas looking at the Ånderson Wall Box, found the original directors sold out the company and formed a new one Simpson & Partners. They make a very nice compact unit, now at revision 3. It looks to tick all the boxes, has all the options now built in, Solar, Load Balancing, no cable to get damaged or vandalised, light on the charge socket so easy to find in the dark.
- 2,364 Topics
- 53.6 K Posts
- 186 Online
- 6,029 Members
TC Thermostatic Radiator Valve TRV Plastic Decorators S...
By Toodles , 3 hours ago
RE: Ecodan unable to hit legionella target temp - what's the consensus?
UPDATE: Thanks everyone who commened with suggestions h...
By 9jwr9 , 8 hours ago
RE: ASHP sizing - value of Heat Transfer Coefficient
@toodles Hi, my friend recently made a video about heat...
By HeatPumpMe , 1 day ago
How long will your energy contract last?
Some heat pump tariffs don’t run as long as a heat pu...
@morgan They are unsupervised these days, can’t get the...
Exactly. We only need to compare conditions, to decide ...
By cathodeRay , 3 days ago
I found because I have very low heat loss I can set bac...
By RadWhisperer , 3 days ago
RE: Need Help Optimising My Rushed ECO4 Install: 12kW Bosch Heat Pump
Welcome @mickamills We too have an oversized 12kW Sa...
By Old_Scientist , 4 days ago
RE: My Powerwall 3 Consumes 3-4 kWh/Day in Self-Consumption: Is This Normal?
@caron I can confirm that the power usage of the PW3 is...
RE: Speedcomfort radiator fans
Thats true, but having tried (and succeeded) in constru...
@bash brilliant, thanks for the feedback
By energy9165 , 4 days ago
RE: Heat Pump Heats the House… But It’s Not Cosy. Emitter Changes or System Tweak?
@alastair There I was, feeling grumpy, he said “Cheer u...
By Toodles , 4 days ago
RE: Grant Aerona: Is there a setting to keep the 2-port valve open during pump blockade
Depends on OAT. Mine cycles at OAT>10 and of course...
@transparent My conclusion is as you have noted, tha...
By Bash , 4 days ago
RE: Mitsubishi Ecodan R290 10kW performance
And to you too. Wishing you a very enjoyable festive s...
RE: External pipework insulation
They do? But that isn't apparent from the photos we'r...
@velcro welcome to the forums. Please feel free start a...
By Mars , 5 days ago
Daikin EDLA11D3V3 DHW Settings
I have a newly installed EDLA11D3V3 which I'm still get...
By Velcro , 5 days ago
