Posted by: @andycooI’ll maybe create a separate post with all the info on our system and what ideas I have 🙂
Yes please do
Posted by: @andycoototal heating season requirements based on four 1 tonne pallets of pellets and one of fuel logs (24000 kWh).
Suggesting a loss in the region of 9kW. Very rough and ready but not 21kW.
- 2,104 Topics
- 46.3 K Posts
- 155 Online
- 3,393 Members
@bart It's a pleasure. If you need anything else, feel ...
By Brendon Uys , 41 minutes ago
@old_scientist I am attaching the consumption and solar...
By Toodles , 1 hour ago
Is anyone else with an Aira heat pump experiencing issu...
By ChandyKris , 2 hours ago
By rossowheels , 15 hours ago
By Majordennisbloodnok , 22 hours ago
By Lucia , 2 days ago
By Scalextrix , 2 days ago
By Damon Blakemore , 4 days ago
By Mars , 5 days ago
By downfield , 5 days ago
By Sune , 5 days ago
