MCS guidelines and complaints - Ground Source Heat Pump installation and servicing
I have been trying to learn about what standards, guidance, and training the MCS provides for corrosion prevention in GSHP systems, and have not been able to learn anything in the past three months of searching. I also would like to know whether GSHP installers/service providers need to have a Water Regulations Certificate and/or an Unvented Hot Water Certificate for installation, commissioning, and servicing of GSHP - as OFTEC requires as a pre-requesite for anyone who wants to take their GSHP courses.
In order to file a complaint against an MCS-certified installer, one needs to know whether they may be in violation of MCS standards. Or is the MCS missing standards for water quality and corrosion prevention in GSHP (or heat pumps in general)??
Hi @phowardstutterheim - I did spot your post arriving on your other topic this morning, but I was busy trying to resolve an unrelated issue in China.
There may be others here who know/understand the regulations for GSHPs and MCS approved installations.
But in the meantime, could you give us any better idea of what sort of water you have in your location?
I grew up in Wiltshire (think - chalk steams) and now live in West Devon (granite & soft water).
So I appreciate the widespread differences in water types which are geographically imposed.
Posted by: @phowardstutterheimI have been trying to learn about what standards, guidance, and training the MCS provides for corrosion prevention in GSHP systems, and have not been able to learn anything in the past three months of searching. I also would like to know whether GSHP installers/service providers need to have a Water Regulations Certificate and/or an Unvented Hot Water Certificate for installation, commissioning, and servicing of GSHP - as OFTEC requires as a pre-requesite for anyone who wants to take their GSHP courses.
If you have not already done so, I would suggest that you get the water analysed to see what may be causing the corrosion.
Have done/am doing so, via Hydratech - https://www.hydratech.co.uk/fluid-testing-and-analysis-closed-loop-systems
They found no inhibitors in the hot water side, and the pH was 6.
They are analysing the refrigerant side now. Yesterday, my husband measured a pH of 6, Brix = 15.5 (polypropylene glycol content = 20% 2/2 or 19.4% v/v, and small particles are present - when exposed to oxygen, the water turned rust colour.
Apparently, only MCS-certified installers have full access to the standards?
Our mains water quality is fine - just on the hard side. Water analysis found no scaling in our system, no biological contamination on the hot water side. We just installed a Sorbox filtration system that supposedly takes care of everything - but not in time to prevent a lot of corrosion that has already occurred. We want to know what our installer/service company were trained / told they should do to prevent this.
So the brine is acidic.
pH isn't high enough.
I'm unsure whether system inhibitor would've been adequate to raise it.
I would expect it should be lying between 7.3 - 7.8
- 2,761 Topics
- 65 K Posts
- 2,056 Online
- 7,168 Members
I agree, and I think it is good stuff to be posting, as...
By cathodeRay , 3 minutes ago
I bought it, read it, enjoyed it. Despite my earlier c...
By JamesPa , 3 hours ago
Our PV set-up has moved over time. Warning this is a sh...
By Judith , 16 hours ago
RE: Where heat loss surveys seem to go against practical reality
@cathoderay @jamespa I've managed to get some nice re...
By Rob of York , 24 hours ago
RE: 7kW EV Charger Options Advice
Doh, not sure that I was thinking straight there, less ...
By Rusty , 1 day ago
I’m really liking reading through this thread and the r...
By Judith , 1 day ago
Thank you @trebor12345
By rgabor , 1 day ago
Panasonic Free Multi Z and Etherea Internal units.
My prospective installers have suggested the Panasonic ...
Great. You just need to find a way of cranking up your...
We had two heat pumps installed without Govt funding. H...
By Rob of York , 2 days ago
My Adapt is finally installed and running! Almost a yea...
By tomasmcguinness , 2 days ago
Thanks, @batpred. That integration is the one I have in...
RE: How Accurate Is My DIY Heat Loss Calculation?
@batpred I suspect it will be more this year. I had 9 ...
By AndrewJ , 5 days ago
