Why run a disinfectant cycle ?
My heat pump has been dutifully running the disinfectant cycle every week, but I read and hear that the jury is still out on whether this is really necessary. What do other people think ?
I have to go into Installer mode to change it, and I can only run it at the same time every week, or not at all. As it uses a significant amount of energy I would have liked to be able to control the timing eg run it when the grid is producing lower co2 electricity, or when the outside temperature is warmest.
If it's not really necessary I'm going to switch it off and get a much better COP.
Posted by: @heat-pump-newbieMy heat pump has been dutifully running the disinfectant cycle every week, but I read and hear that the jury is still out on whether this is really necessary. What do other people think ?
If your water is already at 50C then you're going to have to heat it 10 deg to 60. For a 200l tank that's circa 8kwh at a COP of 1. So a couple of quid a week at the most. You could always have a really hot legionella-free bath to make up for it.
On the other hand the risk is extremely low (1) of legionella getting into your unvented cylinder and (2) you catching it from said cylinder.
It also doesn't like even moderately hot water (this from Wikipedia):
Temperature affects the survival of Legionella as follows:[3]
- Above 70 °C (158 °F) – Legionella dies almost instantly
- At 60 °C (140 °F) – 90% die in 2 minutes (Decimal reduction time (D) = 2 minutes)
- At 50 °C (122 °F) – 90% die in 80–124 minutes, depending on strain (D = 80–124 minutes)
- 48 to 50 °C (118 to 122 °F) – can survive but do not multiply
- 32 to 42 °C (90 to 108 °F) – ideal growth range
- 25 to 45 °C (77 to 113 °F) – growth range
- Below 20 °C (68 °F) – can survive, even below freezing, but are dormant
I would have thought the risk with HW at 48 deg is vanishingly small and that you're in more danger from scalding yourself with your 60 degree, guaranteed legionella free water once a week.
I think it is probably unnecessary but we will never hear the end of it from boiler fans if a heatpumped tank hosts an infection, so I have the standard controller set to still run the cycle the least often as a safeguard (monthly I think, at 0100GMT so cheap electricity and before the coldest part of night) and my add-on smart controller heats a tank of 52˚c water on any moderately warm late afternoon (so cheaper heating) which should kill most of it.
For best risk reduction, remember to run any seldom-used hot taps every so often, especially if the pipe to it is in a warm place such as next to heating pipes. Still water in pipes is probably a far bigger risk than the tank.
Ecodan unable to hit legionella target temp - what's the consensus?
2 months ago
Sudden drop in COP
7 months ago
Nibe F2040 periodic warm water increase fails
10 months ago
Heat Pump, DHW, UFH and Radiator Install
1 year ago
Mitsubishi Ecodan - Hot Water Settings
2 years ago
- 2,539 Topics
- 59.1 K Posts
- 752 Online
- 6,818 Members
By JamesPa , 17 minutes ago
By JamesPa , 1 hour ago
By Boycey , 3 hours ago
By ChandyKris , 4 hours ago
By JamesPa , 6 hours ago
By Papahuhu , 6 hours ago
By Majordennisbloodnok , 7 hours ago
By TechnoGeek , 7 hours ago
By Gruff2001 , 10 hours ago
By Papahuhu , 10 hours ago
By antonical , 11 hours ago
By Mars , 12 hours ago
By JamesPa , 13 hours ago
By RobS , 1 day ago
By antonical , 1 day ago
By Boycey , 1 day ago
By Judith , 1 day ago
By antonical , 2 days ago
