When do you turn your heat pump off?
At what external temperature do you turn your heat pump off and remain comfortable inside?
I'm running our ASHP on full weather compensation, but there must be a point that it becomes unnecessary to heat the house and I'd like to set the controller to deactivate the system when this external temperature is reached to minimise electricity use.
Alternatively, I could revert to using zoned thermostats to heat rooms on demand in this period. I have a feeling full weather compensation will be less efficient because it won't be necessary to run the system 24/7 as we move into March/April...
Thoughts?
Ours does hot water, so it's never turned completely off.
When the heating isn't needed probably depends on how good your insulation is. Once it gets to 12° outdoors, we probably don't need it.
Once the warmer months arrive I don't switch off but just set the thermostat back to 14C and the system "sleeps" through the summer doing the occasional hot water top up when the solar thermal hasn't quite got the tank up to temperature yet. The tricky part is " when are the warmer months"? Last year I set it for 1st May and had to quickly revise that as the garden was white with frost and in fact it turned out downright cold with overnight frosts until well into June. It can be a wee bit chilly on this exposed NE Scotland hill. I am aiming for the 1st May again this year more in hope than expectation! I might have to look out the thermals.
- 2,406 Topics
- 54.6 K Posts
- 386 Online
- 6,092 Members
No because its NOT connected to the neutral, its connec...
By JamesPa , 32 minutes ago
RE: Please help with the settings ecodan
Hi and welcome to the forums.Does your system use a Mit...
By Sheriff Fatman , 44 minutes ago
RE: New Daikin 11kW Altherma 3M install - is it working as it should?
I forgot to mention: Octopus measured our heat loss at ...
By Toodles , 2 hours ago
RE: Considering MLCP (Multi-Layer Composite Pipe) for ASHP
Thanks Mars and thank you for reaching out to so many p...
By iotum , 2 hours ago
Forum Handle: @davec Manufacturer: Peak Energy Mode...
By DaveC , 2 hours ago
@radwhispererdwhisperereorourkeditor Well, the guy came...
By razz , 2 hours ago
Given the weather has been relatively stable, the empir...
By Batpred , 3 hours ago
RE: Post-Traumatic Heat Pump Stress Disorder
@jamespa Hi James - thanks so much! That sounds like ut...
By johnbroome , 4 hours ago
RE: Heat pump not reaching flow temperature
@jamespa system design was for 40 degrees FT at -2 degr...
By DaveC , 4 hours ago
RE: GSHP WOES! Midland based engineer recommendations?
@editor That is very kind! Thank you so much.
@wally Hi I am not sure how large your house is b...
By TechnoGeek , 5 hours ago
RE: Predicted Heat Loss & Needs from MCS calcs vs EPC vs actual
I've been thinking along similar lines to @tim441 from ...
By Sheriff Fatman , 5 hours ago
Thanks, @technogeek. Good to hear about the accuracy. ...
By Majordennisbloodnok , 6 hours ago
In my case it was a very specific pattern of behaviour ...
RE: Vaillant aroTherm not heating with many faults
@ashp-bobba Yeah I'll give it a go, will check filter...
By Anon67 , 6 hours ago
@transparent Perhaps the names at the end of the docume...
By Toodles , 7 hours ago
RE: Heatpunk Floor plan issues
@jamiejones85 A2A they will design on dynamic heat loss...
By ASHP-BOBBA , 7 hours ago
RE: Fan unit Making terrible noise HELP!!
can you post a video looking inside, at and through the...
By ASHP-BOBBA , 8 hours ago
RE: Power outages and storms: A surprisingly good DNO experience
Agreed, which is no more nor less than a customer shoul...
