Weather compensatio...
Weather compensation and air source heat pumps
23 Users
50 Reactions
34.8 K Views
(@alec-morrow)
Honorable Member Contributor
Posted by: @editor
I think, on paper, this sounds like a great and useful system. For me, I don’t understand why all big make heat pump manufacturers don’t have intelligent and highly effective weather compensation built in as standard.
They do…at least the more comprehensive manufacturers  do.
Nithing new about weather compensation either, it was mandated on all heat generators in 1985 in Germany..
Too many interests exist to keep it out of the U.K. though!
Professional installer
@derek-m, can you please refresh my memory which heat curve you’d suggested for us..
54C46504 843C 4B73 A946 966520C3A599
(@alec-morrow)
there are no hard and fast answers..
as it’s depends on emitter size and type, thermal performance of the buidling as well as how long at the higher temerature time period of the controller
essentially the bigger the area of the emitter the lower the curve, that’s why floors have curves as low as 0.5, and convectors curves as high as 4.5
The curve is the rate of change of the flow temperature, a radiator which ha smaller heated area than a heated floor needs a faster rate of change to put the same amount of heat in the room..
A longer on period enables a lower curve, and lower flow temperatures too
Id start at 1.4. the controller will have micro adjustments, it may even auto adapt.
What brand is the controller, and what other control are there?
@editor
Probably try 1 or 1.2 first and see how your system performs.
@derek-m, the one aspect of weather compensation I’m grappling with is whether it’s just a heat curve that adjusts itself on outdoor temperatures only, or does it also take note of the indoor temperature.
In other words, for weather compensation to work on a system, does it need an accurate outdoor and indoor temperature reading?
(@alec-morrow)
@editor some do some dont
gernan manufactures generally have it sorted with no indoor sensing, as the outdoor sensor is mandated in germany
people may like to ask how and why it works with  only an outdoor sensor!
(@batalto)
@alec-morrow I have tested this by logging my power use over last winter and also logging the average weather temperature outdoors. The line is more or less straight, with a slight curve at very low temps. You can see it in my signature. At the end of this month i'll start logging again. Currently the weather isn't cold enough to give anything meaningful - cold nights and warm days really mess with the averages
262m2 house in Hampshire
Posted by: @editor
Hi Mars,
It is my understanding that WC sets the WFT dependent upon the programmed curve and the outside temperature. You may therefore get variations in the indoor temperature caused by solar gain, wind chill, rain effect and even human activity
Also having an indoor temperature sensor helps mitigate these factors by sensing any variation from the setpoint and slightly adjusting the required WFT. Obviously, it only accurately controls the temperature in the room in which the indoor sensor is located, so you may find South facing rooms are warmer due to solar gain and North facing rooms are cooler. This is where balancing of the heat emitters may be needed to even out some of the temperature differences, or use of TRV's.
(@benseb)
Quick Q
I’ve tweaked our WC curve. It’s been running at between 25-39c this week.
today for example it’s 11c outside and running at 26c flow. 5c delta.
however the heating is only running for about 60% of the time.
Is that expected for a “low and slow” run? Or should it be running more?
Is that just down to it still being fairly warm-ish outside?
(@alec-morrow)
@benseb
assuming there are no other controls, the thing to do is to monitor room temperatures, not what the heat pump is doing...afterall thats why you have heating.. to have warm rooms when you want them...
Hi Benseb,
Just as a car engine has a minimum speed, so does a heat pump. What is probably happening is that your thermostat, if you have one installed, is switching off your heat pump, or if you are using weather compensation, the controller is switching off the heat pump because there is insufficient load, even at minimum speed, and the return water temperature is increasing and reducing the Delta-T.
As Alec suggests, monitor the actual indoor temperature along with the other temperature readings.
@derek-m, you’ve read through a lot manuals and looked at weather compensation graphs from different manufacturers. Are the heat curves usually quite similar?
Page 6 / 12
