Using Annual Gas Consumption to understand what an ASHP may consume in electricity
@markc I wasn't able to get the MMSP - I just cant find an installer who will do it
@markc when i asked they just said they didn't do it. I imagine they cant be bothered with the admin required.
@batalto, my supplier agreed, almost reluctantly, to supply MMSP when I asked them. However, it's clear they haven't done it before and it's still not working properly. Mind you, I haven't paid anything for it yet. There is extra admin but it's not that much.
I would also recommend it; the part that is working for me is very useful/interesting. It will definitelly help in optimising the system.
- 2,102 Topics
- 46.2 K Posts
- 48 Online
- 3,388 Members
@skyefarmer great you located the source of the issue a...
By Mars , 3 hours ago
By ASHP-BOBBA , 12 hours ago
From what you say about the radiators upstairs it does ...
By JamesPa , 17 hours ago
By Mars , 20 hours ago
By Mars , 23 hours ago
By downfield , 3 days ago
By Sune , 3 days ago
By Aventus Eco , 4 days ago
By Tim441 , 5 days ago
