Stu , my surveyor said Kraken sometimes replaces radiators with ones of less output which has to be manually corrected, either he forgot or the monster overruled.
Oh my days! 🤦🏻♀️
No wonder my install team hasn't quibbled over my radiator 'asks' so far. Maybe I'll push for a K3 in the living room. 🫢😁😂
@lucia Wow they were keen to sign me up. Brad called at 17:15 yesterday and I asked for a couple of changes. The form was updated but I insisted on going through it carefully but might sign on Sat. I did have a good look and was happy and blow me Octopus was on the phone at 14:00! Luckily I had your referral in front of me so that has gone through OK but he stayed on the line till I had signed which I was happy to do but it did seem a bit high pressure.
Daikin 6Kw ASHP.
MG4 EV
@jancold Double wow! 😳
Someone chasing a bonus? Or commission payments?
My sales person was fairly aggressive but not that much. Thanks for giving them the referral code - let's see what happens. 🤞🏻
Do you have an installation date yet?
Daikin 6Kw ASHP.
MG4 EV
The British Gas would have left me with a cold Kitchen and Octopus agree more closely to mine though My design was predicated on 44 C flow so I believe I have leeway to lower the flow temp.
Anyway I have decided on Octopus so onwards.
Daikin 6Kw ASHP.
MG4 EV
It's count down time (give thanks because it's becoming cold) and I have a date for gas capping and removal of meter! This time next week my little home will be officially de-carbonised. I should have a kick-out carbon party!
It will however be a few days after that before I get heating. I'm going to use my entire first tank of hot water on one long, hot shower. It's a shame I am only getting the 180 litre tank. 😂
Your kitchen would not have been cold, 18 degrees C is the temperature kitchens should be designed to because there are significant amounts of equipment that continuously run (fridges etc) that supply thermal gains. bedrooms should be 18, and living rooms to 21.
I have not seen the house so cannot comment on the actual scizing.
@heacol Sorry Brendon, but there is no ‘should be’ about it! The temperatures in my house are what I desire them to be, I live in it, not an advisory body like MCS! Regards, Toodles.
Posted by: @toodles@heacol Sorry Brendon, but there is no ‘should be’ about it! The temperatures in my house are what I desire them to be, I live in it, not an advisory body like MCS! Regards, Toodles.
Posted by: @heacolYour kitchen would not have been cold, 18 degrees C is the temperature kitchens should be designed to because there are significant amounts of equipment that continuously run (fridges etc) that supply thermal gains. bedrooms should be 18, and living rooms to 21.
I have to say I agree completely with @toodles' response that "there is no 'should be' about it".
Ultimately, the design of a heating system for a house ought to be a collaboration between customer and supplier. I quite understand that someone in @jancold's position might not appreciate the thermal gain characteristics of appliances normally kept in a kitchen and so find it useful to have an expert explain the extra factors needing to be accommodated. However, it's still the customer's house as @toodles rightly points out.
I should point out, by the way, that plenty of people have domestic arrangements that put the equipment mentioned outside the kitchen; freezers in utility rooms or garages, for instance. The rather open-plan layout of my own house means the fridge/freezer and the washing machine are both outside the kitchen and, in order to avoid any problems of damp, our cooker sits under a VERY efficient cooker hood meaning the hobs and ovens don't significantly increase the heat either. The idea that kitchens "should" be designed to a lower temperature than other rooms relies on assumptions, but those same assumptions can be verified or debunked by the heating designer simply by looking around when doing the heat survey and by talking with the occupants of the property.
Are Octopuses Slowing Consumer Adoption of Heat Pumps?
6 days ago
7 months ago
7 months ago
Daikin Error Code 7H05
10 months ago
10 months ago
- 33 Online
I think either can be highly reliable or highly unrelia...
By Old_Scientist , 3 minutes ago
For best results with induction hobs use stainless stee...
By Scalextrix , 46 minutes ago
Central heating still switched off and will be until Oc...
By AllyFish , 3 hours ago
Please read to the very end of this post, I shift my po...
By JamesPa , 3 hours ago
By cathodeRay , 18 hours ago
By ASHP-BOBBA , 19 hours ago
By dgclimatecontrol , 21 hours ago
By Lucia , 1 day ago
By ASHP-BOBBA , 2 days ago
By Tim441 , 2 days ago
By HCas , 2 days ago
By jamespetts , 2 days ago
By GrahamF , 3 days ago
By immunity , 3 days ago
