Two Heat Geeks say that an ASHP for my property will cost £25,000
@toodles That may have happened Toodles, as when I spoke to my brother in law about it he was concerned about the pipes being on the wall when they convert the garage. It was a non problem really as he already had 15mm rad pipes on there and boxing out the wall would only have reduced it by an extra 1cm or so. I think i might have advised him differently had i been there.
- 2,102 Topics
- 46.2 K Posts
- 124 Online
- 3,388 Members
By JamesPa , 13 minutes ago
By Scalextrix , 24 minutes ago
And we have it: DESNZ are now investigating the feasi...
By Lucia , 4 hours ago
By ASHP-BOBBA , 17 hours ago
By downfield , 3 days ago
By Sune , 3 days ago
