Treating your heat pump against rust
Graham Hendra posted an interesting piece today about treating your heat pump annually with ACF50 to prevent it from rusting: https://renewableheatinghub.co.uk/showing-your-heat-pump-some-love-with-acf50
It's actually an interesting point. Our ASHP is now 3 years old with no signs of rust, but I guess the casing is going to start degrading in time – how are all your heat pumps ageing?
Never heard go ACF50 ( https://amzn.to/3q2m93E) prior to this post either. Looks like interesting stuff. Any one else used ACF50?
Free UK shipping.
📘 From Zero to Heat Pump Hero
🛠️ Bodge Buster
New to heat pumps?
Posted by: @editorGraham Hendra posted an interesting piece today about treating your heat pump annually with ACF50 to prevent it from rusting.
Never heard go ACF50 prior to this post either. Looks like interesting stuff. Any one else used ACF50?
Yup, it's very common and well thought of in motorcycle circles. When I rode/commuted year-round I used it to good effect on the bikes. Good idea.
@kev-m, thanks. I’ve never heard of it. Will get a can and give it a go.
Free UK shipping.
🛠️ Bodge Buster
New to heat pumps?
A quick heads up from a motorcyclist of 30 years - and an 30 yr Industrial Chemist.
ACF50 is amazing stuff and I've used nothing else for decades. However - I AVOID direct onto electrical parts on motorcycles, e.g., connectors. Seen a few issues from this over the years, (mostly older connectors mind). Oh and if using on bikes, motorbikes DO NOT SPRAY ONTO BRAKE DISCS. You'll get a nasty suprise if you do (You wont stop - at all!).
Putting the chemist hat on for a mo - The safety sheets for this stuff don't do it justice IMHO.(see below).
They just talk about eye safety mostly. I use gloves, glasses, washable overall and apply in well ventilated area and don't breathe the smoke when it burns off exhaust.
The stuff is full of various length hydrocarbons in an Ingredient called "Hydrotreated Oils CAS 72623-85-9" Its a real mix of hydrocarbon chains and a Cat1 Carcinogen. The Clue is in the Carc. 1B H350 in table 3.2 And in section 16.
H372: causes damage to organs through prolonged or repeated exposure
H350: may cause cancer
Net, contact / breathing should be avoided for obvious reasons - so dont use it like hairspray.
I personally AVOID the aerosol - and buy the paint on version instead - more application precision (cheaper too in long run).
Does it work?..... - you betcha - beyond anythign else you can buy - its expensive but worth it.
But PLEASE be careful in application and avoiding contact.
Kipper
Edited for typos
- 2,775 Topics
- 65.4 K Posts
- 1,383 Online
- 7,180 Members
@agentgeorge I cook in time for lunch @ 13:00 (one of t...
By Toodles , 2 minutes ago
By Batpred , 15 hours ago
By Toodles , 20 hours ago
By tomasmcguinness , 1 day ago
@mrkfm, I'd also suggest that whenever you're ready, st...
RE: Are you planning to use a wood burner to supplement your central heating this winter?
I use my stove daily for backup and comfort. Definitely...
By Margarethomas , 2 days ago
@rob-of-york Thanks. I wish I'd started on this site as...
By mrkfm , 2 days ago
@downfield I just checked this morning and OE just r...
Thanks Will. I'll probably be a week or so before get...
By Singlespeed , 3 days ago
From experience this summer, a single-split A2A unit on...
By Rob of York , 3 days ago
Analysis of the economics of switching to an A2W ASHP compared to other heat sources
This post aims to analyse the economics of installing, ...
By Rob of York , 4 days ago
@editor does that mean you have to have two separate ex...
By mrkfm , 4 days ago
