From thinking about a 7kW Vaillant ASHP to a subpar installation and my complaint.
Hi Mars @editor
Im on with the Rec complaint are you able to reply please to my last emails . I value your opinion on this, along with getting a second opinion on the install if you can recommend ? Thanks again S
@suzyq, send me what you’ve written as a draft to complain with to RECC and I’ll take a look.
@suzyq we’ve got the ball rolling. Now your patience is bound to be tested by RECC and the parties they ‘delegate’ to.
- 61 Online
Yes. They cost about £400 to buy or you might be able ...
By JamesPa , 9 minutes ago
If that's the case then you are right to be sceptical, ...
By JamesPa , 21 minutes ago
Havenwise App Help & Forum Support – Get the Most from Your Heat Pump
We’re pleased to announce that Havenwise are now joinin...
By Mars , 1 hour ago
By Lucia , 3 hours ago
By JamesPa , 4 hours ago
By jamespetts , 12 hours ago
By ASHP-BOBBA , 14 hours ago
By JamesPa , 15 hours ago
By Tim441 , 18 hours ago
By Transparent , 20 hours ago
By HCas , 23 hours ago
By jamespetts , 23 hours ago
By jamespetts , 24 hours ago
By GrahamF , 2 days ago
By immunity , 2 days ago
Just done your survey!
By Judith , 3 days ago
