Samsung Gen6 setting I can't fathom: water outlet heated to 64C.
Our system seems to be operating as it should apart from one random (doesn't seem to be linked to time of day or outside temp) issue.
No more than once a day and not everyday the system will heat "Water Outlet" to 64C. No heat is cycled through radiators as the two remote zone thermostats are not asking for heat so the zone vales are closed. It does this with and without Zone screen "off".
The Operation Status screen shows Comp Operation/ Water Tank and Water Pump as in use.
I have failed to find a setting that will stop this happening ............... has anyone seem similar ?
TIA
Samsung 12kw ASHP, nine 415w PV panel array, upgraded radiators and DHW water tank (+ pumps etc). Two wireless zone thermostat controllers and Samsung MWR-WW10N
The pump came on again early this morning.
I took more pics but I can't see any clues apart from "Thermostat 1" being "on" in Zone status info ?
ASHP ran on until outlet temp reached 64.
The lights on zone valve boxes above show neither were calling for heat.
@lenny The main Thing that comes to mind is that the heat pump is heating your domestic hot water tank. This is about the only time you would expect the flow temperature to reach 60° or more.
Thanks.
Heat pump does heat/maintain DHW but max temp is 55 (I wonder if it is running random disinfection cycle ? }
@lenny When you say the max temperature is 55 deg C, I presume you mean the max temperature that your DHW is heated to. That is the default maximum. However the flow temperature from the heat pump (the water outlet temperature in your screenshot) will be at least 60 deg C to achieve the 55 deg C temperature of the domestic hot water. Otherwise, it wouldn't heat your hot water to 55 deg C.
@lenny If you have Solar PV, it would probably save you a lot of money to install a Solar iBoost or similar device. This will heat your hot water from the electricity produced by your solar PV for free for at least half the year. My Samsung doesn't get used at this time of year. Failing that, it is also probably cheaper to schedule when your heat pump heats your hot water. There is inevitable heat loss from the tank and pipe work, so unless you need piping hot water all the time, heating it once or twice a day is more economical.
Set DHW on a schedule and this AM it came on proving that it was just as you suggested 🙂 . not a "issue I couldn't find" just me not thinking sideways enough.
Also the iBoost suggestion, I have been thinking about that
Thanks
I have the same pump as your self and a 4kw solar array. I would strongly advise you to get an Iboost. My iboost heats my water approx 9mths in the year. As I have nowhere else for my free energy to go I have the tanks set for 70C. I also have the HP coming on in the late afternoon so any "free" solar during the day is used to heat water, the HP is set to heat the hot water to 48c which is adequate for us as a back up to solar. The HP is only set for 1 hour which is long enough to heat to 48c and has never failed to achieve that. Limiting the schedule saves you money.
thanks.........
The HP coming on via the iBoost or with the PV setting in the Gen6 controller ?
@mike-h - can you possibly point me towards any advice on how to install iBoost with a Samsung Gen 6 ashp? I have searched the forums, but can't find out whether to wire iBoost directly to the immersion, or disconnect immersion from Samsung, before connecting iBoost? Flumoxed (I have a qualified electrician trying to sort this for me). Thanks in advance 😁
- 2,658 Topics
- 62.2 K Posts
- 357 Online
- 7,064 Members
Directory
RE: How can I cool inverter and batteries during hot spells?
I think it's going to depend on the size of your loft. ...
By EtchedPixels , 21 minutes ago
@batpred You have to look at the maths carefully and yo...
By EtchedPixels , 31 minutes ago
RE: The Reality Behind a Failed Heat Pump Installation – and an IWA Insurance Rejection
Quite possibly the most honest thing they’ve said, then...
By Majordennisbloodnok , 41 minutes ago
@jamespa they are based about 50 mile away so probably ...
By AdamK , 3 hours ago
@judith Agree, sometimes the simplest solutions just...
By Batpred , 5 hours ago
RE: Who Actually Owns a Heat Pump in Britain? We Asked. Here Is What We Found.
Er if course it will, thats the whole objective. Do be...
By JamesPa , 9 hours ago
@will-h an official welcome to the forums and hopefully...
By Mars , 10 hours ago
We are still working on the Grant R290 - but since my l...
By Will H , 12 hours ago
Because lots of people in small houses and fla...
@wanttobegreen really good spot. The FT carried this...
By Mars , 16 hours ago
@majordennisbloodnok, @davidalgarve — yes, very happy t...
By cathodeRay , 16 hours ago
@trebor12345… thanks for sharing! Really valuable info ...
@jamespa I am all for pre engineering… Would I be ...
