Replacing knackered oil boiler with ASHP - Perthshire
On the basis that 1l oil = 10kWh and 1cu m wood = 2500kWh, the total is between 25+10=35 and 40+10=50 MWh per annum. That's definitely in the same general ball park (dividing by 2000-2900 depending on which calculation you prefer) so I would say that the heat loss calculations are at least plausible. So basically I'm with @bontwoody
Id be tempted to consider something like a 16kW heat pump (or the largest reasonable one you can find, avoiding anything too extreme) with some backup heating for the coldest days if it turns out you need it! Or an 8 and a 10 kW or similar running either alone or together.
@abernyte thanks tbh I was more thinking about bolstering the insulation within the timber frame which would entail removal of plasterboard etc. and a massive amount of disruption.
- 2,171 Topics
- 47.8 K Posts
- 37 Online
- 5,744 Members
If it is measuring (and only measuring) the OAT, it is ...
By cathodeRay , 32 minutes ago
Thank you for raising your concerns. Customer safety, s...
By Mixergy , 1 hour ago
By GrahamF , 1 hour ago
By cathodeRay , 1 hour ago
If the 'cellular technology' is actually the GSM system...
By Transparent , 1 hour ago
@jamespa Ours is a Daikin EDLA03 8 kW and the Delta T =...
By Toodles , 2 hours ago
Day one is done. The system’s been fully flushed and ...
By Mars , 17 hours ago
By cathodeRay , 18 hours ago
By Toodles , 19 hours ago
By Sheriff Fatman , 22 hours ago
By Paul G , 2 days ago
By pash44pump , 4 days ago
By JamesPa , 5 days ago
By Cleardene-ashp , 5 days ago
By JulianC , 5 days ago
