Real world running cost estimate for 20KW ASHP
Posted by: @thebarnYes, it is very confusing to have been quoted 11kw, (16kw when I looked into it a few years ago), then 18kw and then 20kw! Go in too low and be cold and too high and be wasting electricity and money.
The ideal is to go for for something that just exceeds your heat loss at design temp (-2 or thereabouts depending on where you are) when running at those outside air temperatures. Any more, and you will get more cycling at warmer weather, as the heat pump can't reduce it's output below a certain level, and less and you will be likely to feel cold when it is very cold outside. That is what I ended up with: nominal 14kW unit, but only coughs up a little over 11kW at around zero outside, estimated heat loss 12.3 kW, result is actual indoor air temp falls a bit below desired indoor air temp during cold weather.
As others have said, heat loss calculations are not an exact science, and in some cases I suspect involve the use of random numbers. But a tolerably thorough assessment should usually give you a reasonable ball park figure. That said, there has been a lot of debate in other threads about empirical measurements (albeit rather crude, because of the surfeit of variables involved), and how these often do not agree with the heat loss calculator estimates.
- 2,114 Topics
- 46.4 K Posts
- 9 Online
- 3,410 Members
Watching Gary Does Solar’s latest YouTube video on the ...
By ChandyKris , 4 hours ago
By thewiseoldbird , 8 hours ago
By Transparent , 16 hours ago
By JamesPa , 17 hours ago
By Prunus , 3 days ago
By Transparent , 6 days ago
By Wh0am3ye , 6 days ago
By TechnoGeek , 1 week ago
