[Sticky] Rate the quality of your heat pump design and installation
@johnmo Interestingly (or possibly not that interesting) but I’ve found a free app called iLet Comfort that has connected to my system and lets me see and control the heating and DHW settings from my iPhone. It also purports to show the COP but I’ve only been using it for a day so that’s to be seen.
Is this ASHP install OK?
1 month ago
My Journey to Finding the Best Heat Pump for My Home in France
6 months ago
What is the most important factor for you when choosing a heat pump brand?
1 year ago
Mid terrace - ASHP Install location
1 year ago
Any installer recommendations for Samsung ASHP?
2 years ago
- 48 Online
@editor So… who’s given in and turned the heating on al...
By Lucia , 6 minutes ago
By ASHP-BOBBA , 44 minutes ago
@jamespa Thanks. Yes, its a bit sad so many of these jo...
By ASHP-BOBBA , 54 minutes ago
I managed to find a perfectly good new but 'last years ...
By cathodeRay , 1 hour ago
By dgclimatecontrol , 2 hours ago
If that's the case then you are right to be sceptical, ...
By JamesPa , 7 hours ago
By Lucia , 9 hours ago
By ASHP-BOBBA , 21 hours ago
By Tim441 , 1 day ago
By Transparent , 1 day ago
By HCas , 1 day ago
By jamespetts , 1 day ago
By GrahamF , 2 days ago
By immunity , 2 days ago
Just done your survey!
By Judith , 3 days ago
