[Sticky] Rate the quality of your heat pump design and installation
@johnmo Interestingly (or possibly not that interesting) but I’ve found a free app called iLet Comfort that has connected to my system and lets me see and control the heating and DHW settings from my iPhone. It also purports to show the COP but I’ve only been using it for a day so that’s to be seen.
Is this ASHP install OK?
1 month ago
My Journey to Finding the Best Heat Pump for My Home in France
6 months ago
What is the most important factor for you when choosing a heat pump brand?
1 year ago
Mid terrace - ASHP Install location
1 year ago
Any installer recommendations for Samsung ASHP?
2 years ago
- 17 Online
By jamespetts , 6 hours ago
By ASHP-BOBBA , 7 hours ago
By ASHP-BOBBA , 8 hours ago
By JamesPa , 9 hours ago
By Tim441 , 12 hours ago
By Toodles , 12 hours ago
By Transparent , 14 hours ago
By HCas , 16 hours ago
By jamespetts , 17 hours ago
By jamespetts , 18 hours ago
By GrahamF , 2 days ago
By immunity , 2 days ago
Just done your survey!
By Judith , 2 days ago
By Tasos , 3 days ago
