Mid terrace - ASHP Install location
If you used the wall mounted option, it would improve air flow as there is no fence that high. You still have the problem of the 1m rule for planning though.
Is this ASHP install OK?
1 month ago
Rate the quality of your heat pump design and installation
4 months ago
Any installer recommendations for Samsung ASHP?
2 years ago
Ecodan - optimal external installation?
2 years ago
Any recommendations for ASHP installers in the North West?
2 years ago
- 57 Online
By JamesPa , 9 minutes ago
@jamespetts Lots of things to unpack here so I will co...
By JamesPa , 23 minutes ago
By Tim441 , 4 hours ago
Hell no, October as a matter of principle. If I had my ...
By Toodles , 4 hours ago
@dgclimatecontrol I have no intention of removing the...
By Morgan , 5 hours ago
By Transparent , 5 hours ago
By HCas , 8 hours ago
By jamespetts , 8 hours ago
By jamespetts , 9 hours ago
By HCas , 1 day ago
By GrahamF , 1 day ago
By immunity , 1 day ago
Just done your survey!
By Judith , 2 days ago
By Tasos , 2 days ago
By Scalextrix , 3 days ago
