Method for monitoring ASHP usage/efficiency in real time?
Hi
I have an Mitsubishi Ecodan ASHP that was installed 4 years ago. The Ecodan controller shows energy consumed/delivered, but I need to go outside to an outbuilding (where the Ecodan and cylinder is located) to view this. Is there a free/cheap app/technology that I can view this information on my phone for example?
Posted by: @broosterDo you have the MELCloud app?
Unless you have a new version of the app that I haven’t seen, it won’t give real-time energy usage stats; only previous day and before. You can see current temperature, but not how the HP is performing to achieve that temp.
Posted by: @majordennisbloodnokPosted by: @broosterDo you have the MELCloud app?
You can see the current day; just overwrite the dates. You can keep the report open and press the energy button to update it. Not quite real time but close. At least I can, this is today so far (it's going to be expensive!). I have MMSP monitoring though.
The MELcloud API gets more data than can be seen in their app, including energy consumption and heat movement with about 2 minutes delay. Third -party apps like my melcloud-mqtt-bridge can feed that to home automation dashboards like domoticz or HA.
Another option is to connect your own device to the cn105 connector which will see real time but I think then you can't also use melcloud. Or you can fit your own sensors. Many options.
Hmm, I dont, but Ive just Googled for it. Looks good, but do I need a seperate 'wifi controller' or is it already built in? (The Ecodan is about 4 years old, so quite modern)
Posted by: @tuftyPosted by: @broosterDo you have the MELCloud app?
you need one of these or similar.
I didn’t get MMSP installed with mine so unlikely to be worth fitting at this point. Does anyone know if you can hook up an electric meter pulse counter to the FTC5 without also hooking up the heat meter?
just so I know the electric consumption is accurate?
Posted by: @bensebDoes anyone know if you can hook up an electric meter pulse counter to the FTC5 without also hooking up the heat meter?
I think you'd have to hook it up to an electricity meter because the FTC doesn't pulse, as far as I know. Another option may be CT clamps on the supply lead. I've no experience with either but they're used by people on the open energy monitor forums.
Posted by: @bensebI didn’t get MMSP installed with mine so unlikely to be worth fitting at this point. Does anyone know if you can hook up an electric meter pulse counter to the FTC5 without also hooking up the heat meter?
This is how you hook up power and electricity meters. They are separate connections so I assume you can do one without the other. T
- 2,724 Topics
- 63.8 K Posts
- 444 Online
- 7,126 Members
RE: Microgeneration Certification Scheme (MCS)
I’ve just spotted that Ian Rippin is leaving MCS as CEO...
By Mars , 11 minutes ago
Hi. I have 16 panel solar panels producing about 20k...
By peterackstraw , 4 hours ago
@transparent I’ve heard that that is why American cars ...
By Toodles , 5 hours ago
RE: HeatGeek vs Octopus surveys: puzzling disparity - any ideas why?
Have either quote provided room by room heat loss calcu...
By Old_Scientist , 19 hours ago
@old_scientist if you are going DIY then you may wan...
After a short while that was followed by the 'power war...
RE: Samsung heat pump - data cable issue
That's well done. Cable is the correct type (LIYCY = 2x...
By bobflux , 2 days ago
I agree, we will find out at the next budget whether th...
@editor I went through HG website, so should be ok for ...
By sttpd1917 , 3 days ago
Who did the Freedom Heat Pump cloud server and what did...
RE: Air to air bus grant installer anywhere
The through wall two hole ones have their place (listed...
By EtchedPixels , 3 days ago
I hope it goes ok, Hon can be hard to set up IF the sof...
By Graham Hendra , 3 days ago
@clockworks Hi, So there is a big difference between st...
By ASHP-BOBBA , 3 days ago
@editor wellvery comprehensive answer. I will get all i...
By Keithb , 3 days ago
RE: Advice on my Heat Pump Journey: Old Stone Built Detached Cottage
all good advice I will follow this up
By PaulC , 3 days ago
