How to best configu...
How to best configure my Mitsubishi heat pump to work effectively?
6 Users
12 Reactions
(@hughf)
Posted by: @hughf
@derek-m
One way around it is to use a PWM controlled pump on the secondary circuit too, piggybacked off the ASHP control boards PWM signal (provided it is available, mine is).... But if you're going to do that, you might as well ditch the buffer in the middle.
You have a Samsung ASHP, which does not have an internal water pump, hence the need for the PWM control signal, whether it is used or not, to control an external water pump. I'm not certain if other manufacturer's provide a speed control signal for external water pumps.
I’ve got a Cool Energy unit actually, I’ve just read a lot of the Samsung manuals over the last week.
(@cheshirecat)
In reply to an earlier comment, I don’t appear to have a low loss header.
I have a hot water tank with two pressure vessels in the system, I have a filter and I have two grundfoss pumps which as has been pointed out have a few settings.
There is a pump speed setting buried in the FTC somewhere, I’m nervous to dig around too much as it asks me if I want to switch off the system when I press certain buttons.
The Mitsi certainly seems to put heat over economy in the room adaptation mode.   I’m keeping a close eye on it and I think I’m probably unfortunate in having the ‘learning’ days where we get to know the heat pump in the cold, as the tweaks cost more the longer it takes to get it right.
I’m confident I can get the consumption down though.
I can see boiler flow/ return and another set of temps flow/return- which should have the 5 deg plus loss?
This post was modified 3 years ago 2 times by CheshireCat
(@hughf)
Typical ecodan plumbing schematic is attached. Very simple, no buffer, no LLH
BEA05B1C C260 43AB 8448 9A69D26C7F37
Posted by: @cheshirecat
It's the other flows, not the boiler ones you should be looking at. I think 'boiler' = immersion in Mitsubishi.
Don't worry about the system off warning if you want to have a look around. It's just a standby mode not a hard power down. You start it up again with the round button on the right. I haven't changed the pump settings on mine though.
Page 4 / 4
