Heating and Hot Water Issues with Thermal Store/Heat Pump
Ah ok I will have to get in touch with the manufacturers I think as I don't seem to have a manual for the thermal store, presumably been thrown away as it has a big sticker on the control panel saying not in use.
Is it fairly normal to have lots of different control systems as I think I have about 3 different systems trying to control the room temperature timings but only one of them actually does the controlling I think?
- 2,391 Topics
- 54.2 K Posts
- 248 Online
- 6,074 Members
OK, I'm going to call a halt to this diversion. One o...
By Majordennisbloodnok , 18 minutes ago
RE: Hot water heating in parallel with space heating
An external heat exchanger would need a pump which woul...
By bontwoody , 41 minutes ago
The Sunny boy is old enough that it should be considere...
By JamesPa , 59 minutes ago
@benson Thanks for responding and for your advice. ...
By Wally , 1 hour ago
RE: Heat pump not reaching flow temperature
@johnd, what you’re experiencing is common with air sou...
By Mars , 11 hours ago
RE: Gen 6 Samsung ASHP losing 20C of DHW in 60 min directly after generation
@ecobaker Thanks for this. I've had it in both slots. ...
By andbeck , 11 hours ago
RE: Air source heat pump circuit not operational
Welcome to the forums. If the thermostat shows it’s c...
RE: Daikin Atherma ASHP Cycling 6 Times an Hour?
From what you describe, it sounds like you’ve done a so...
RE: Ecodan with FTC7 - True Weather Compensation
@danwright90 I've linked two videos below recorded this...
By Sheriff Fatman , 13 hours ago
@steelbadger, I’ve pretty much decided now that there’s...
By Majordennisbloodnok , 14 hours ago
That makes plenty of sense. Perhaps more importantly, O...
It does but it almost all applies to boiler systems and...
By JamesPa , 18 hours ago
RE: Installer Fitted 9kW Instead of 11kW Heat Pump and Changed MCS Paperwork - What do I do?
So theres a problem for starters. This means that the ...
By JamesPa , 19 hours ago
RE: Insulating a pitched roof with kingspan, has anyone done it?
Thank you everyone for all of the information, it looks...
By TRBob , 2 days ago
@transparent Yep, they didn’t even mention it. When ...
They are lovely, and I feel lucky to live in one, but t...
Worth adding that, for this tariff, the Octopus app has...
RE: APP for remote Daikin ASHP Operation
Thanks, @newhouse87. Understood. I was only asking on...
@mike-patrick A propos, I think my heat pump generates ...
By dr_dongle , 2 days ago
