Grant Aerona 3 16kW ASHP in 100 year old cottage
Hello,
I have recently moved into a property with a Grant Aerona 3 heat pump. The property is a three-bed, 100-year-old cottage that is well insulated. It has solar panels and solar water. All the heat pump workings, e.g. water tank, etc., are situated in the garage. The garage is not insulted. The heat pump controller is also in the garage. I also have a thermostat (within the house) that controls the heating times in the place.
I am averaging about 50 kWh of energy use per day (£12). I can have the heating set to 20 degrees all day or have it set to come on when the house is occupied, and it makes little difference to the energy use.
I'm using too much energy and have had the installer out to look at it, who change a few settings. I have also had Grant support talking me through a few settings on the phone, all to no difference.
Having looked at the 'heat pump controller', am I correct in thinking this should not be in a cold room? (cold garage). On display, it states that the room temperature is 11c and the outdoor temperature is 6.5c. Is my heat pump trying to get this 11c up to my thermostat is asking, e.g. 20c, thus using excess energy? Should the 'heat pump controller' be located inside my property?
How big is your house? 50kw with the current temperatures might not be crazy. I'm using around 50 per day at the moment as well - but our ASHP is 12kw Vs your 16kw. Given you have a 16kw pump you probably need quite a bit of heat. It's the middle of winter so you would expect it to be cold and your heating going
@batalto Evening, my house is 163m2. I'm new to having a heat pump and don't know what a typical per day use is in winter. On a few occasions, I have had it down to 30 kWh. I wondered if the 'heat pump controller' was in the correct location or if it was ok to be in a cold environment.
@esteii the first question would be, is the system using weather compensation? It should be running off your thermostat in the house given that you've said.
@esteii I would suggest you whack the thermostat up to something like 22 or 23° and see if the house can get to that temperature. If it does then your weather compensation settings are too high. If you trim them down you'll start saving on power costs with no loss of comfort.
I'd suggest doing that in the day, not over night - Unless you want to wake up in a sweat
@batalto it can definitely get to 22 and more as I’ve had that on my settings before when experimenting. What would be ideal weather compensation settings? I can’t remember what I have them set at as the Grant expert changed them.
@esteii I have no idea. Each house will differ as it's determined by the heat loss you experience based on the building fabric. I'd suggest just finding the current settings.
Write them down and then lower the max temperature by a few degrees and see how you get on. Just go day by day and gradually tweak down. You can see my settings as an example my signature but everyones is slightly different. If you have UFH you can go very low, rads you'll be higher.
Posted by: @esteii@batalto it can definitely get to 22 and more as I’ve had that on my settings before when experimenting. What would be ideal weather compensation settings? I can’t remember what I have them set at as the Grant expert changed them.
Hi Esteii,
A possible starting point would be a 0.8C change in water flow temperature for every 1C change in outdoor air temperature.
So, set the cold end of the weather compensation for a water flow temperature of 44C when the outdoor air temperature is -10C, and a water flow temperature of 20C when the outdoor air temperature is 20C.
As Batalto has suggested, see how the system performs over 24 hours, then if the indoor air temperature is too high then lower one of the settings, and vice versa if the indoor air temperature is too low.
Posted by: @esteiiHaving looked at the 'heat pump controller', am I correct in thinking this should not be in a cold room? (cold garage). On display, it states that the room temperature is 11c and the outdoor temperature is 6.5c. Is my heat pump trying to get this 11c up to my thermostat is asking, e.g. 20c, thus using excess energy? Should the 'heat pump controller' be located inside my property?
The way Grant do it, they have a traditional heating thermostat (like a boiler) to provide 'heat please' and 'hot water please' inputs to the heat pump. The (Chofu) heat pump controller is actually capable of doing its own controls being its own thermostat, running its own scheduled on/off programs, etc, but Grant completely disable all of that. By doing so, it's only the location of the external thermostat that matters. (Well, almost - the frost protection is still going to run based on the 'inside' temperature).
I plan to try using the heat pump controller instead of the awful Honeywell 'smart' thermostat I have, and to that effect have moved it out of the airing cupboard into the hall (it's just two wires), but not investigated this yet. I'm not expecting a massive increase in efficiency, but I hope it will help with things like the Honeywell unnecessarily cycling the heat pump.
Here's the full Chofu heat pump manual including the bits Grant cut out:
PS: on cold days my whole house reading is about 40kWh per day (1960s somewhat draughty bungalow, 120m2) so your figure doesn't sound massively off.
Grant Aerona3 - Home Assistant control via Modbus
4 months ago
17kw Grant Aerona heat pump questions about hot water and glycol
3 years ago
ASHP manufactures (NIBE vs Grant)
5 years ago
- 2,771 Topics
- 65.3 K Posts
- 1,678 Online
- 7,174 Members
@rob-of-york I think this gets right to the heart of th...
By Mars , 3 minutes ago
By Mars , 26 minutes ago
By Jimcub , 2 hours ago
By JamesPa , 4 hours ago
@jamespa My RFQ went out to 20 companies via email; in ...
By Toodles , 4 hours ago
By Prunus , 5 hours ago
Hmmm. We have 500sq metres here (including some very hi...
By Carpenterstation , 6 hours ago
Thank you @majordennisbloodnok – that means a lot, part...
Have you looked at the Nibe website? They list their ap...
By Lizzie , 1 day ago
By Papahuhu , 3 days ago
By Batpred , 3 days ago
By Rob of York , 3 days ago
By springswood , 3 days ago
