Emerald Energy ASHP
2 Users
2 Reactions
jamespipe
(@jamespipe)
Just had our new heat pump hot water system installed in our effort to disconnect from gas.
Decided to try out the new Emerald Energy (EE-HWS-A1-270E) so only time will tell if it was a mistake not going iStore or something more premium like a Reclaim.
It's a bit noisy when outside but so far not noticeable indoors and the Wi-Fi app was simple to set up and has a nice interface, but a bit limited in features.
Anyway, please have a look at the pictures and give me feedback on the installation. Overall quite happy with the installation with the only two concerns.
Firstly is the overhang from the concrete block, checking the installation manual it states that it needs to be installed on a 60×60 cm block at a minimum or could void warranty, the block appears to be 59 cm so not sure if I should be concerned
Secondly is that the condensation pipe should be routed to storm water, it was initially installed to drip down the side of the house, but I requested it to be moved, not sure if it needs additional attention. Living in Victoria, the area is quite wet as it is already, but termites are a concern being a wood house.
Installer: Ecogeek.
Emerald heat pump  2
Emerald heat pump  3
Emerald heat pump  4
Emerald heat pump  1
Heat pump installer at ipromiseaustralia.com.au
@jamespipe, when say you live in Victoria is that Victoria, Australia, or Victoria, Canada? I’m guessing Canada.
@jamespipe Can you also post some photos of the plant room? We'd like to see if there's a buffer and how the hot water cylinder is set up. This will help us understand the system layout better and provide more accurate feedback.
jamespipe
(@jamespipe)
Posted by: @editor
Victoria, Australia. 🙂
jamespipe
(@jamespipe)
Posted by: @editor
Okay, will post soon.
@jamespipe are you using this for hot water only?
