[Solved] Ecodan 11.2kW with low 5 litre per minute flow rate leading to L9 error
@paulrlondon did they flush the system round after the last piece of major radiator / pipework? good practice would be to push a load of water through (With the ASHP not connected) to flush objects just like that out, or make them get caught in a filter inside the property.
- 2,391 Topics
- 54.2 K Posts
- 277 Online
- 6,074 Members
Interestingly we've been well under 0 for a few days no...
By jamesh , 44 seconds ago
RE: Heat pump not reaching flow temperature
is the house warm enough?
By davidnolan22 , 9 minutes ago
Running from backup generaor in powercut?
Does anyone have experience of running an ASHP from a b...
By Pipcart , 14 minutes ago
@wally, welcome to the forums. I’ll probably repeat a ...
By Mars , 43 minutes ago
RE: Daikin Atherma ASHP Cycling 6 Times an Hour?
Thanks for your reply. Yes that's a good idea to try a...
By John Marshall , 1 hour ago
OK, I'm going to call a halt to this diversion. One o...
RE: Hot water heating in parallel with space heating
An external heat exchanger would need a pump which woul...
By bontwoody , 2 hours ago
The Sunny boy is old enough that it should be considere...
By JamesPa , 2 hours ago
RE: Gen 6 Samsung ASHP losing 20C of DHW in 60 min directly after generation
@ecobaker Thanks for this. I've had it in both slots. ...
By andbeck , 12 hours ago
RE: Air source heat pump circuit not operational
Welcome to the forums. If the thermostat shows it’s c...
By Mars , 12 hours ago
RE: Ecodan with FTC7 - True Weather Compensation
@danwright90 I've linked two videos below recorded this...
By Sheriff Fatman , 14 hours ago
@steelbadger, I’ve pretty much decided now that there’s...
That makes plenty of sense. Perhaps more importantly, O...
By Majordennisbloodnok , 16 hours ago
It does but it almost all applies to boiler systems and...
By JamesPa , 19 hours ago
RE: Installer Fitted 9kW Instead of 11kW Heat Pump and Changed MCS Paperwork - What do I do?
So theres a problem for starters. This means that the ...
By JamesPa , 20 hours ago
RE: Insulating a pitched roof with kingspan, has anyone done it?
Thank you everyone for all of the information, it looks...
By TRBob , 2 days ago
@transparent Yep, they didn’t even mention it. When ...
They are lovely, and I feel lucky to live in one, but t...
Worth adding that, for this tariff, the Octopus app has...
