Daikin COP / energy used measurement from MMI
@crasher sorry, I missed your message.
I haven’t found a fix for this. I mentioned it to Octopus and a Daikin engineer when they visited and they were not very interested, stating that it was only approximate anyway.
So I setup ESPAltherma and have had it running for 3 months with Home Assistant:
https://raomin.github.io/ESPAltherma/
It is excellent and provides great insight into what your Daikin is doing.
@hcas I’ve got the Daikin integration for Home Assistant; it seems to show the same (bad) electricity data as the MMI 😔
@squarepeg77 Thanks for the reply. I never got an answer either but it just resolved itself, checked it a few days after posting here and all was good again I had readings back! I don't believe it to be 100% accurate but it gives a guide to how the unit performs. I've found the same with Daikin, they never seem overly interested in providing any help
@squarepeg77 Hi! Is it your ESPAltherma that is connected to Home Assistant? Or are you using the Onecta API for the Home Assistant?
And the ESPAltherma gives you the same wrong readings as the Onecta app and MMI?
Have you set up any home automation or smart steering of your heat pump?
Both ESPAltherma and Daikin integration connect to Home Assistant.
The Daikin integration exposes sensors that match the ONECTA app or MMI; so for me that means incorrect electricity consumption.
ESPaltherma is much lower level, but the electricity (voltage and current) sensors are considered inaccurate, so people seem to be using external monitoring. I’ve got a CT clamp around the heat pump feed that goes back to an Eddi, then I collect the data in HA.
If you want to get going with ESPAltherma, there’s an excellent guide here:
And yes, I am running a software thermostat in Home Assistant as the Madoka is too “quirky” for my liking.
Warm weather and heat pumps.
4 months ago
Oversized Daikin 9kw
4 months ago
7 months ago
Daikin Error Code 7H05
9 months ago
11 months ago
- 2,148 Topics
- 47 K Posts
- 43 Online
- 5,666 Members
@tim441 As an annual event, I used to record the Christ...
By Toodles , 5 minutes ago
How Do I Know When the Hot Water Has Run Out?
This is an apparently simple question: how do I know wh...
By GrahamF , 7 minutes ago
This is one of my biggest bugbears these days, how AI d...
By cathodeRay , 55 minutes ago
Firstly can I say again that I am sorry to hear about y...
By JamesPa , 1 hour ago
@pash44pump - @jamespa has anticipated my next steps bu...
By cathodeRay , 1 hour ago
I have to ask, are you mining cryptocurrency? What do y...
By DREI , 5 hours ago
The gas standing charge went up as some of the network ...
By Jeff , 14 hours ago
By HCas , 2 days ago
By SAEnergy , 3 days ago
By Temperature_Gradient , 3 days ago
By Toodles , 4 days ago
By GrahamF , 4 days ago
By Old_Scientist , 5 days ago
By ASHP-BOBBA , 6 days ago
By Majordennisbloodnok , 7 days ago
By Old_Scientist , 1 week ago
