Could position cause a potential noise nuisance to me?
It would seem the ideal position for a 7kW Vaillant Arotherm plus is under our kitchen window. This would work very well for us as well in principle as the only other potential position would take up half the path down the side of our house and have a wall approx. 1m (maybe a bit more) from the front face of the pump. However, approx. 8ft above the top of the heat pump if sited under the kitchen window is our bedroom window and my head, in bed, is about 3ft in from that (window is triple glazed). Additionally the 28mm flow and return pipes would run up the side of the wall very close to this bedroom, into the loft above my head and then across the loft space to the airing cupboard.
I know heat pumps are not intrinsically noisy (which I believe) but I can't help but be a bit concerned that there might be enough noise to disturb my sleep from either the pump, water in the pipes flowing through the pipes or vibrations through the roof timbers. Probably more importantly if it disturbs my wife who would be further from the window but I expect under the pipe routing in the loft.
Any thoughts from people with a pump/pipes under/by their bedroom?
We have the flow and return pipes from our Daikin ASHP monobloc running up the wall on the side of our bedroom window without any problem. I don’t know if any audible noises emanate from those pipes, but if it does, I suspect that the insulation must be reducing it anyway. Normal practice is to fit flexible pipework to the return and flow connections on the heat pump and this usually isolates much of the vibration being transmitted and transferred into those rigid pipes up the wall.
NB. We live in a very noisy ambient sound level due to traffic, (roads, railway and aircraft) and cannot hear anything from our heatpump unless we are within a metre of the housing. Regards, Toodles.
Post script: We normally sleep with the double glazed window open and it has not caused any loss of sleep or any irritation due to the heat pump running. Please see photo, that horizontal run on the right is to the airing cupboard in our bedroom and that is the window I mention.
Regards, Toodles
@toodles Thanks! In my case, the pipes would run where your soil pipe does and into the loft (our soffits are probably 40-50cm wide) Our bedroom window was originally a door so it's pretty much a floor to ceiling window so looking at your photo, it would probably run to about half way between your bedroom and kitchen windows. Good point about the flexible coupling.
Cheers - it certainly seems like it ought not to be an issue so that's good.
My cylinder, buffer tank and the hot water circulating pump are in a room underneath my bedroom (which has become noticeably warmer). There was audible noise from circulating water when the pump was at maximum speed (as left by the installers) and I reduced it to medium speed without reduced noise and no adverse effect on circulation. Recently, after monitoring temperatures in / out of the buffer tank I've reduced the pump to minimum speed which gives slightly better heat transfer, minimal flow noise and the heat still reaches the extremities. I haven't found any way to control the flow rate of the pump built into my Arotherm+ but the primary circuit uses 28mm pipes whereas the pipework to the radiators is smaller. Bigger pipes reduce the flow velocity (and hence potential to make noise) in proportion to the diameter squared.
@johnr We currently have an oversized (seriously oversized) pump in the airing cupboard by the bedroom door at the moment and I don't hear that and I'm not bothered about the 15mm pipe work as obviously that's already in the bedroom and not an issue. It sounds to me like it's not going to be an issue with the 28mm pipes.
- 2,820 Topics
- 66.9 K Posts
- 3,321 Online
- 7,236 Members
My current solar inverter isnt battery capable, so I do...
By JamesPa , 9 minutes ago
You may notice that Mars is advertising a book called '...
By JamesPa , 1 hour ago
100% agree about this particularly as many manufacturer...
By JamesPa , 6 hours ago
By Mars , 7 hours ago
By HeyMikey , 8 hours ago
@fosterl2 I'm sure it's over simplified as there'...
By Singlespeed , 8 hours ago
By the same measure we should be insisting that all gas...
By Batpred , 20 hours ago
I do not disagree with the concept of wanting to live a...
By Batpred , 21 hours ago
RE: Grant Aerona - Weather Compensation and Schedules
@taffonthetaff Yes, I have now gotten to the bottom of ...
By bontwoody , 23 hours ago
Occasionally our Grant R290 activates all three circuit...
By TaffontheTaff , 23 hours ago
@davec 47kwh for 3 days is very low, compared to what I...
By johnd , 1 day ago
