Benefits of improved insulation.
The following link shows some of the benefits of improved insulation.
Having watched this, I think it's a really useful posting with one caveat.
For most people and most properties, it's basically highlighting what is a no-brainer; improving poor insulation will provide huge returns on investment. My only caveat is for properties old enough not to have been designed with cavity walls. In those cases simply reducing the heat-losing airflow is highly likely to introduce humidity problems so the process of insulating an old property needs to be tackled with the involvement of an expert. I certainly wouldn't suggest it can't be done but it needs to be done using advice from someone who understands the technicalities of retaining heat whilst still allowing the building to breathe.
Fortunately there are a number of good firms out there to consult with on this and some fantastic "heritage" insulation products available. Still a very worthwhile step to take.
- 2,792 Topics
- 66 K Posts
- 1,923 Online
- 7,196 Members
Before changing pump settings, check the filter, flow d...
By EnergyStorageTech , 12 minutes ago
To me an excessiveness of emojis screams AI written tex...
By Prunus , 19 minutes ago
I think that's the key question. After all inverter uni...
By Prunus , 27 minutes ago
With battery-only storage, the tariff spread is only pa...
By EnergyStorageTech , 35 minutes ago
RE: tepeo ZEB UK Support & Info Thread
The comparison should separate storage-heater behavior ...
By EnergyStorageTech , 55 minutes ago
A unit which uses water to transfer the heat/chill from...
By Temperature_Gradient , 2 hours ago
With regards to the BUS grant raid, I gave it more thou...
By ASHP-BOBBA , 2 hours ago
The whole system seems to work on the basis of...
By ian33a , 2 hours ago
Good plan. If you can get half hourly meter readings a...
By JamesPa , 7 hours ago
@editor Most certainly. The heat pump was an ideal s...
By Abernyte , 8 hours ago
Although regulations may well vary from country to coun...
Yep I caught our slow leak from a £100 bill rise 8)
By EtchedPixels , 8 hours ago
RE: Do You Need a Buffer Tank or Low Loss Header for Underfloor Heating in a Large Property?
@jamespa in some cases, failing the Turing test might b...
By GrahamF , 11 hours ago
@energystoragetech The heat capacity of some...
By JamesPa , 13 hours ago
