Ariston or Acond Heat Pumps?
Does anyone have any experience with the performance either of these two makes of heat pump? A friend has been quoted for them from Thermal Earth. I know the Acond is Czech and uses the R290 refridgerant instead of the usual R32, but thats about it. My feeling is to steer him towards a more mainstream make but Im willing to be persuaded.
- 2,396 Topics
- 54.3 K Posts
- 425 Online
- 6,077 Members
I too think that the Solis earthing diagram is confusin...
By Transparent , 8 minutes ago
Vaillant aroTherm not heating with many faults
I have a 3 year old 10kW vaillant aroTherm heat pump co...
By Anon67 , 41 minutes ago
RE: Considering MLCP (Multi-Layer Composite Pipe) for ASHP
OK, TBH I dont know enough about MLCP to comment with a...
By JamesPa , 1 hour ago
RE: Predicted Heat Loss from MCS calcs vs EPC vs actual
My gut feeling is that the heat pump is right sized. ...
By Tim441 , 2 hours ago
RE: Heat pump not reaching flow temperature
Peak Energy Products most recent accounts (to June 2024...
By JamesPa , 2 hours ago
RE: Power outages and storms: A surprisingly good DNO experience
Agreed, which is no more nor less than a customer shoul...
By Majordennisbloodnok , 3 hours ago
@batpred In our case, 3 times each day when the Octopus...
By Toodles , 4 hours ago
Hi @sheriff-fatman Cycling at 5C and below is usuall...
By RobS , 4 hours ago
@batpred Here's the latest Fogstar ready built pack....
By Bash , 6 hours ago
@mike-patrick yes, even though the current system is ru...
By Tim441 , 6 hours ago
Solis confirmed that the S6 works with a single battery...
By Batpred , 6 hours ago
I am wondering if in any V2X, would the car battery eve...
By Batpred , 7 hours ago
Yes, by calculating it manually from the minute data, w...
By cathodeRay , 8 hours ago
Fan unit Making terrible noise HELP!!
One of a pair of fan units on an Earth Save Classic II ...
By GutoFfowc , 9 hours ago
OK. I think your system, which seems well designed, is...
By JamesPa , 10 hours ago
RE: Heatpunk Floor plan issues
It's usually the complete opposite... seldom that Safar...
By Mars , 24 hours ago
RE: Fan is clipping ice build up from the front of unit.
@majordennisbloodnok I’ll not go there thanks! Toodles.
By Toodles , 1 day ago
RE: Running my new Nibe ASHP efficiently
I'm new to the forum. Did you get a reply to this last ...
By Mike @ Camelot , 1 day ago
@grantmethestrength MCS requirements for DHW capacity h...
