An abject and utter failure...
I have been meaning for a while to see what data has been published about Green Home Grant applications and installations, for both the Voucher scheme and the LAD schemes. These schemes, it must be remembered, are THE main way the government intend to get us Luddites to take up low carbon energy. If they fail, the whole thing fails.
Background: in late 2020, the government announced plans to install 600,000 heat pumps in the UK every year until 2028... 600,000 x 8 = 4.8m
Rather amazingly, the data is available. Here are the headline figures for England for all GHG ASHP installations:
GHG Voucher Scheme: 3,968 (to 7th(?) Feb 2022)
LAD Phase 1: 773 (to end Feb 2022)
LAD Phase 2: 116 (to end Feb 2022) (and I am presumably one of those 116 installations...)
There are around 25,000,000 dwelling in England. You can do the maths as well as I can...
Sources:
GHG Voucher scheme (Table 2.1)
LAD scheme (Tables 1.1 and 1.2)
Posted by: @cathoderayI have been meaning for a while to see what data has been published about Green Home Grant applications and installations, for both the Voucher scheme and the LAD schemes. These schemes, it must be remembered, are THE main way the government intend to get us Luddites to take up low carbon energy. If they fail, the whole thing fails.
Sources:
I'm afraid that you need to understand that when someone obtains a job at BEIS or MCS, the first requirement before they are allowed to start work is that they have to have a lobotomy, so that they are completely devoid of common sense.
Posted by: @hamish-mcmichaelcan you post the link to the data please?
The links are there, I posted them with the original post, but for some reason they don't stand out as links. Hover over the left hand end of each of the three lines under 'Sources', and you should see them change, the cursor changes to a finger/pointer and the linked to site appears at the bottom of the screen. They work as links for me when I click them. The first two are xlsx data files, the third is a pdf.
@editor - maybe CSS not behaving as it should on the links?
Posted by: @derek-mthe first requirement before they are allowed to start work is that they have to have a lobotomy, so that they are completely devoid of common sense
Which leaves the rest of us feeling like we need lobotomies, to avoid feeling pain of living in a mad world. I suspect MCS are are major factor in why the UK ASHP industry is in the state it is.
"For the rejected applications, 49 per cent were rejected as the application was deemed ineligible."
I'm sorry, what?
Posted by: @hughf"For the rejected applications, 49 per cent were rejected as the application was deemed ineligible."
I'm sorry, what?
I should wait till after coffee before trying to digest that spreadsheet - I thought that was 'illegible', hence my utter confusion 🙂
@hughf - the whole thing is eye-watering. The minute numbers of actual installs is only the headline...
- 2,539 Topics
- 59.1 K Posts
- 305 Online
- 6,818 Members
By JamesPa , 4 hours ago
By JamesPa , 5 hours ago
By Boycey , 7 hours ago
By ChandyKris , 8 hours ago
By JamesPa , 9 hours ago
By Papahuhu , 9 hours ago
By TechnoGeek , 11 hours ago
By Gruff2001 , 13 hours ago
By Papahuhu , 13 hours ago
By antonical , 15 hours ago
By Mars , 16 hours ago
By JamesPa , 17 hours ago
By RobS , 1 day ago
By antonical , 1 day ago
By Boycey , 1 day ago
By Judith , 2 days ago
By antonical , 2 days ago
