[Sticky] Air source heat pump roll call – what heat pump brand and model do you have?
Forum Handle: Judith
Manufacturer: Vaillant
Model: Aro THERM Plus 7kW (achieves 8.3kW)
Type: ASHP
Arrangement: Mono
Area of Country: South Coast
Home Type: House 1950s detached
Size: Square Metres: 198m^2
Insulation Level: 7/10 300mm in loft, cavity wall beads or foam, Ar filled double glazing, BUT solid concrete floor in original house
Heat Loss Calculation: 7.5 kW by installer @ Amb. Temp, of:20.5 @-2C OR 6.5kW to 7kW using bills/smart meter and 6.5kW my calculations
Type of Controller: Vaillant Sensocomfort 720 TRV's on all old, but not on replacement, rads.
Type of Control: Weather Compensation (in expanded mode at present to prevent over-heating with solar load with large south facing windows)
System Type: Mostly Radiators, single zone 42C water flow temperature at external design temperature
Total Output of Heat Emitters: ~30kW at delta 50C
Buffer Tank or Low Loss Header: 26L Volumiser, on heating output side
Secondary Pumps: one post mixer for UFH in extension which needs an always lower temperature for floor covering
Solar PV System: 6kW 4kW with SunnyBoy Inverter (original FIT tariff) + 2kW on Growatt 2kW inverter
Power Diverter: No
Solar thermal system for DHW vacuum type
Battery System: Yes 9/5kWH Givenergy with AC 3 inverter
Household ventilation by MVHR. Baseline air leakage <1 ACH
Wood burner stove <5kW output
Needed planning permission (straight-forward) since pump mounted on side wall at the front can be seen from the road
Forum Handle: MikeH
Manufacturer: Aira
Model:Aira 8kW
Type: ASHP,
Arrangement: Mono,
Area of Country: Nottingham
Home Type: Dethatched House (1899),
Size: Square Metres: 112
Insulation Level: 6 (half externally insulated, double glassed, 300mm loft)
Heat Loss Calculation: 8.6kW @ Amb. Temp, of: -3.2C
Type of Controller: Aira wireless remote controller
Type of Control: Unknown, assume Weather Compensation,
System Type: Radiators (5 upgraded)
Total Output of Heat Emitters: unknown
Buffer Tank or Low Loss Header: 40l Buffer Tank
Secondary Pumps: 1
Solar PV System: 3.8kW
Power Diverter: No
Battery System: No
Forum Handle: ArundaleP
Manufacturer: Samsung
Model: AE080BXYDEG/EU (8kW HTQ)
Type: ASHP
Arrangement: Mono, High Temp capable.
Area of Country: Sussex
Home Type: House
Size: Square Metres: 101
Insulation Level: 6/10 (uninsulated concrete floor, 300mm in loft, insulated cavity walls, old UPVC double glazing)
Heat Loss Calculation: 6 kW @ Amb. Temp, of: -1.9C
Type of Controller: Homely
Type of Control: Adaptive, Weather Compensation, Flow Temperature, Room Influence, tariff optimised.
Tado set to all open but limits bedroom temps at night.
Total Output of Heat Emitters: kW
Buffer Tank or Low Loss Header: No
Secondary Pumps: No
Solar PV System: 5.9kW
Power Diverter: No
Battery System: 9.7kWh
We also have a Nissan Leaf and vehicle to grid charger which is used to extend the use of off peak electricity in the winter evenings (vehicle to heat pump).
A lot of home automation is used to make all the systems work together efficiently.
Sunamp for hot water storage.
Insulation upgrades:
EPS cavity wall insulation.
Forum Handle: pj_preston
Manufacturer: Daikin
Model: Altherma 3 9kw EDLA09DA3V3
Type: ASHP
Arrangement: Monobloc
Area of Country: Location Preston. North West England
Home Type: Detached 3 Bedroom Bungalow
Size: Square Metres: Original 80 sq m, Extended 32 sq m Total 112 sq m
Insulation Level: Original 6, Extended 8
Heat Loss Calculation: 6.827kW @ -3.2C
Type of Controller: Daikin Weather Dependant with Leaving Water Temperature Control. TRV’s and 2 zone UFH. Madoka is installed in central hall and MMI in services cupboard.
Type of Control: Weather Compensation and LWT Weather Dependant
System Type: Radiators for 80 sq mtrs and UFH for 32 sq mtrs
Total Output of Heat Emitters: 8.923kW
Buffer Tank or Low Loss Header: Volumiser installed in loft area
Secondary Pumps: Number or No No.
Solar PV System: Size or No No.
Power Diverter: Yes or No No.
Battery System: Size or No No.
Apprentice Retiree
Forum Handle: jamespetts
Model: Arotherm + 7kW
Type: ASHP
Area of Country: London
Home Type: 2 bed mid-terrace
Size: Square Metres:67.15
Insulation Level: ?
Heat Loss Calculation: 6.4kW @ -1.8C
Type of Controller: Vaillant sensoCOMFORT VRC 720f/3 + Honeywell EvoHome for TRVs
Type of Control: Weather Compensation + (independent) Honeywell TRVs
System Type: Cast iron radiators
Total Output of Heat Emitters: 8..898kW
Buffer Tank or Low Loss Header: Low loss header
Secondary Pumps: One
Solar PV System: 8kW peak
Power Diverter: No
Battery System: Not yet but possibly in future
Manufacturer: Grant
Model: Aerona 3 - 6kw
Type: ASHP
Area of Country: Ireland, Cork
Home Type: House detached
Size: Square Metres: 182
Insulation Level: 8/9
Heat Loss Calculation: Unknown
Type of Controller: Grant standard controller, 2 zone stats
Type of Control : Weather compensation
System Type: UFH up and downstairs
Buffer Tank or Low Loss Header: BT
Secondary Pumps: No
Solar PV System: no
Power Diverter: No
Battery System: No
Manufacturer: Octopus
Model: Cosy6
Type: ASHP
Arrangement: Mono
Area of Country: SE
Home Type: House - semi-detached
Size: Square Metres: 75
Insulation Level: EPC B (after ASHP and Solar PV)
Heat Loss Calculation: 4.1kW @ Amb. Temp, of: -2.4C
Type of Controller: Cosy Hub
Type of Control: Weather compensating
System Type: Radiators (with 10mm PEX microbore)
Total Output of Heat Emitters: 4.6kW @ dT30
Buffer Tank or Low Loss Header: 26L volumizer on the CH return
Secondary Pumps: none
Solar PV System: 2.64kWp azimuth 145 tilt 40 with Enphase microinverters
Power Diverter: none
Battery System: 2 x Enphase IQ5p (5kWh, 3.2kW AC)
I really don't have a lot of this information, but I'll fill what I can:
Forum Handle: eqwilts
Manufacturer: LG
Model: HM091MR
Type: ASHP
Arrangement: Mono
Area of Country: North Wiltshire
Home Type: House
Size: Square Metres: 65
Insulation Level: Scale of 1 to 10 possibly? Don't know how to calculate that, loft insulation, double glazing, cavity wall insulation
Heat Loss Calculation: kW @ Amb. Temp, of: ?C
Type of Controller: Smart Single Thermostat, dumb trvs
Type of Control: Adaptive, Weather Compensation, Flow Temperature, Room Temperature etc.
Buffer Tank or Low Loss Header: No info supplied
Secondary Pumps: No info supplied
Solar PV System: 3.2kw
Power Diverter: ?
Battery System: 2 x 3kw
Mitsubishi Zubadan 14kW with Mixergy 210l DHW
@downfield May I point you in the direction of this topic about the anti-legionella system used by heat-pumps to prevent the growth of bacteria in the DHW tank...
... and then this topic which discusses possible software deficiencies in the anti-legionella cycle implemented by Mitsubishi heat-pumps.
In particular, your 210-litre DHW tank is borderline for whether a 3kW immersion heater can actually raise the water temperature sufficiently high during the 60-min window in which it operates.
The quality of the pipe insulation around the tank needs to be high.
Please make responses in those topics, rather than here.
Forum Handle: adrian
Model: Arotherm plus 5
Type: ASHP
Arrangement: Mono
Area of Country: Oxfordshire
Home Type: semi detached house
Size: Square Metres: 100
Insulation Level: 8
Heat Loss Calculation: 4kW @ Amb. Temp, of: -2C
Type of Controller: Vaillant thing
Type of Control:, Weather Compensation .
Total Output of Heat Emitters: 4.5kW @45C
Secondary Pumps: no
Solar PV System: 4.3kwp
Power Diverter: No
Battery System: 9.5kwh
- 2,104 Topics
- 46.3 K Posts
- 85 Online
- 3,393 Members
@old_scientist Another point I might have made a little...
By Toodles , 9 minutes ago
By Lucia , 22 hours ago
By Brendon Uys , 1 day ago
By Scalextrix , 1 day ago
By ASHP-BOBBA , 2 days ago
By downfield , 4 days ago
By Sune , 4 days ago
