Below is an extract from the MIM-E03CN manual, which is the recommended controller for use with your heat pump.
Do you only have the one water pump?
Is your system still short cycling at the same frequency?
One possible problem could be incorrect settings within the controller. If possible go into the installer menu and make a note of any parameter settings that you can find, and then post the results.
@derek-m I have two pumps I believe. You can see both pumps in this pic.Â
I am still getting short cycling, yes.Â
What settings do you mean, sorry?Â
It's entirely possible the settings are incorrect, I've had to wing it to get as far as I have.Â
What is the temperature setting of the two thermostats, and what is their make and model?
@derek-m okay, I'm not at home at the moment. I'll do it later and report back. I've made various adjustment to water law which is Samsung for WC. The temp in the house is nice and the COP is acceptable too. Just the cycling. Thanks again
The Joule Samsung instructions are available on line, they don’t use a PWM pump. They have a separate interface PCB that comes after the MIM. I’ll see if I can find a link.
I would be inclined to get the installer to wire/plumb it up as per the Midsummer wholesale instructions that give details on how to fit a PWM pump and use the Samsung controller as the room stat.
- 2,208 Topics
- 48.7 K Posts
- 47 Online
- 5,868 Members
I installed the 80L tank (volumizer) things got better ...
By immunity , 2 hours ago
RE: Mitsubishi Ecodan F8 error
I absolutely love this. This is the quintessential heat...
By Mars , 9 hours ago
@papahuhu at the end of the day if you are happy with h...
By benson , 14 hours ago
RE: Can you recommend a Mitsubishi service engineer in the Rochdale area?
@dgclimatecontrol We'll all need annual servicing. How...
By Suzy-shadow , 14 hours ago
@transparent I’ve understood your point now. The point ...
By Judith , 15 hours ago
Does indeed need checking, @tim441. Neither Homely ...
Delighted to hear that the buffer has been replumbed as...
By JamesPa , 16 hours ago
RE: Daikin 9kW to 8kW Swap Offer from Octopus
Yes but 9kW is similarly the 16kW derated. So 8kW subs...
By JamesPa , 17 hours ago
Actually, there's a rather greater degree of cattle-her...
By Majordennisbloodnok , 18 hours ago
RE: The Hidden Secret to a Successful Heat Pump: Pipe Size Matters
@davidnolan22 So far as I can tell from the 'other p...
By JamesPa , 22 hours ago
I keep getting havenwise ads on my Facebook feed, so cl...
By benson , 24 hours ago
Automation options to maximuse efficiency & ToU tariffs
I started a conversation with ChatGPT. What automation...
By Tim441 , 1 day ago
RE: 4 Year Ongoing Heat Pump Battle With Poor Heat Pump Installation
@jamespa Oh, I know some that are good and some not so....
By ASHP-BOBBA , 1 day ago
RE: Samsung Heat pump with Yonos Pico circulating pump running all the time
I don't know how many pumps you have but I guess it's o...
That's just human nature unfortunately, not special to ...
@bontwoody how long has it been now since you started t...
Yes, over the last few days I've been keeping a very cl...
By Steelbadger , 2 days ago
Absolutely. I am one of those members and I most certai...
