As you say, nothing appears to be changing dramatically. Though I fail to understand how your home is maintaining an indoor temperature of 18C, with an outdoor temperature of 6C.
Now try setting your system in fixed LWT mode with a setting of 35C.
Â
@derek-m I've no idea. 🤣
I turned the system off for the Octopus saving session at 17:30 room stats showing 18. Went out and came back at 20:30. Turned back on and room stats were at 17.5. Not sure if you need that info but just in case it's relevant.Â
I'll have to work out how to set fixed lwt mode. I'll do it tomorrow. Thanks again.Â
@derek-m overnight it was 4 degrees and it has struggled to keep 18. The house is at 17.5 this morning. COP is down to 3.3 and it's using more power and running for longer. 15.6kw yesterday 13.3hours operation time (that's with turning off for 3hours)and a generation of 51.7.
Posted by: @craig1980Is this what you mean?
Â
Yes, that would appear to be the correct method. Try running with a LWT of 35C and see how the system responds, and if it stops the 20 second off periods.
Â
Okay, that's done. It was already on standard temperature "water outlet". Could that have been an issue?Â
How is the system operating now? Is it still running 8 mins on and 20 secs off?
What is happening with the room and radiator temps?
What are the flow and temperature readings etc?
Changing the way that the system is being operated is to try to find what is causing the 20 seconds shutdown.
So, it appears to run constantly but at quite high power usage of 1.9kw instantaneous power.Â
Rads feel warmer to the touch but room temp stays at around 18 according to room stats and thermometers that I used for radiator temps.Â
Outside temp is 6.0 according to wired remote.
Water outlet 35.4
Indoor 21.5 (remember, this is in the airing cupboard with the UVC).Â
Posted by: @craig1980So, it appears to run constantly but at quite high power usage of 1.9kw instantaneous power.Â
Water outlet 35.4
Now measure the top and bottom temperatures on two or three relevant radiators, and the flow rate and temperature readings from the information screens.
Â
- 22 Online
One other thing, I haven’t balanced the rads yet so cur...
By AdamK , 4 minutes ago
By DREI , 19 minutes ago
Possibly not the answer you might want, but if it were ...
By Temperature_Gradient , 2 hours ago
By JamesPa , 4 hours ago
By Cleardene-ashp , 6 hours ago
By JulianC , 7 hours ago
By NJT , 8 hours ago
By Toodles , 9 hours ago
By Transparent , 9 hours ago
By Old_Scientist , 15 hours ago
By cathodeRay , 1 day ago
By ASHP-BOBBA , 1 day ago
By Lucia , 2 days ago
By ASHP-BOBBA , 2 days ago
By Tim441 , 2 days ago
By HCas , 2 days ago
By jamespetts , 2 days ago
