RDSAP10 effect on existing heat pump EPC rating?
There is a real disconnect between how performance is captured for RHI and what ends up being used for EPCs via RDSAP.
The SPF of 4.1 you got probably reflects the real-world performance of your GSHP. But RDSAP, being a cut-down version of the full SAP methodology, often uses default or oversimplified figures—hence that laughable COP of 1.7. That number doesn’t reflect the capabilities of a modern MCS-certified system like MCS HP0016/08, especially if it’s been properly designed and commissioned.
To improve the EPC rating and get a COP/SCOP that reflects reality (especially at 40°C flow temp), you ideally want to use the Product Characteristics Database (PCDB). If your heat pump is listed in there, SAP can pull in the correct performance figures. If not, RDSAP defaults will drag the rating down every time.
And no—SPF and COP aren’t interchangeable. SPF takes into account the whole system and how it behaves across seasons, whereas COP/SCOP is a performance figure under fixed conditions. Related, yes. Swappable? No.
Honestly, if you’re aiming to push the rating from a D to a C and you’ve already got detailed performance data from the RHI assessment, it’s far better to do a full SAP. It’s more work and takes longer, but it allows you to input all the real data properly—emitters, controls, flow temps, measured demand, and system design. That’s where you stand a decent chance of getting the rating
@aaron There's the rub, the database does not list my HP, it appears to begin in 2016. So does this mean we cannot get a COP figure at all? https://www.ncm-pcdb.org.uk/sap/pcdbsearch.jsp?heatPumpType=1&emitterType=3&type=362&serviceProvision=1&brand=&model=&modelQualifier=&pid=31
No Bosch or IVT GSHPs listed.
- 2,177 Topics
- 47.9 K Posts
- 33 Online
- 5,748 Members
RE: Repiping and Reconfiguring our Heat Pump System Including Removing the Buffer Tank
@adamk &@editor I think these FRVs come into their ...
By Judith , 1 hour ago
RE: Which temperature sensor for a Steibel buffer and Ecodan?
@ashp-bobba many thanks for the information. I have f...
By downfield , 1 hour ago
@judith Applied for replacement from installer. If...
By cliffhanger , 3 hours ago
The real answer is trial and error, because there are a...
By cathodeRay , 4 hours ago
@drei Id be wary of the reference in quote 1 to reattac...
By benson , 18 hours ago
RE: Renewable Heating Hub WhatsApp Channel
I clicked on the link and have WhatsApp on the computer...
By dgclimatecontrol , 19 hours ago
Thanks for the warm welcome @editor and can't wait to b...
By Pirate Rich , 21 hours ago
Let's also bear in mind that Fogstar supply more than o...
By Majordennisbloodnok , 24 hours ago
@judith Yes I agree. They are extremely expensive. ...
By GrahamF , 1 day ago
Riello NXHM Monobloc Air Source Heat Pump
Hi, does anyone have any feedback on Riello NXHM Monobl...
By dgarvey , 2 days ago
RE: How to Zone with a Single Room with UFH
We have exactly what you describe, one utility room wit...
By Judith , 2 days ago
@agentgeorge Come the Ist of October, the Cosy cheapest...
@ashfp Mine does have a buffer tank. That was my experi...
By Andrew J H , 2 days ago
I'm sure you are right, I was just trying to understand...
RE: Preparing for 2nd winter in new build house.
Yuch! So that's basically just an on/off control. I...
Good day everyone. I'm new here and have a few question...
By Edin67 , 4 days ago
RE: MCS certificate SCOP vs real-world performance
That may be contributing to lower than expected SCOP. ...
By JamesPa , 5 days ago
How it does it's job is something of a mystery although...
By Abernyte , 5 days ago
